SC10 Thread
You usually use the standard length RPM cups and the turnbuckles should already be in the kit. You do not need the silicone diff lube and you are going to need to do a hex conversion to use those rims. Sorry for the negatives.
The truck is a great truck and you should be happy with it.
I was going to do it, I almost bought a Lucas Oils SC10RS Combo from AMAINHOBBIES.com but my finger slipped and I ordered the following from TowerHobbies.
And because Im an International Customer I get like $170 bucks off
Why? Im old school and have build 7 Tamiya kits when I was a Teenager and figured, I would learn the ins and outs of the car better if I put it together myself. Means I can also set it up exactly how I like it, and I know what to change.
So yeah, did I order enough LOL!
- LXEV21 RPM Long Shank Rod Ends (12)
- LXFDU5 Associated Factory Team Titanium Turnbuckle Set Blue T4
- LXYVK1 RPM Front Bumper Assembly Black SC10
- LXZTJ4 Associated 1/10 SC10 Factory Team Kit
- LXAPZJ Novak Havoc Pro SC/Ballistic Brushless Sys 13.5T/3300kV
- LXZZD1 Futaba 3PL 3-Channel 2.4GHz FHSS Transmitter/Receiver
- LXUZ80 Hitec HS-5645MG Digital Ultra Torque Metal Gear 2BB
- LXSF70 Associated Factory Team Green Slime
- LXSGB8 Associated Silicone Differential Fluid 5,000
- LXAXGA AKA Racing 1/10 GridIron SC Soft w/Red Insert
- LXBRAD AKA Racing 1/10 Cyclone SC Wheel F/R SC10 4x4 Black
- L5DUS102 Associated Body Clips Metallic Blue Short
- LX2932 Associated Body Mount Large Washers Truck (4)
- LXWWA5 AKA Racing Premium Tire Glue
- LXAPDU Associated Silicone Shock Fluid 37.5 Weight 2 oz
- LX3310 Associated Silicone Shock Fluid 35 Weight 2 oz 1
- LX3306 Associated Silicone Shock Fluid 40 Weight 2 oz 1
- LXAPDR Associated Silicone Shock Fluid 32.5 Weight 2 oz
Hmm didnt know about the wheels, I thought the FT kit was the same as the RS Spec and came with the 12mm hexes.
Can anyone confirm?
If not then..... bugger.
Great choice to move away from the RTR if you've been in the hobby prior. You'll want to use the +3 Hazzard wheels instead of the AKA wheels you listed below. Also, to run the hex wheels, you need to convert your factory team to the Hex system (steering carriers and axles for front; hexes all around).
The diff oil isn't needed as you're a given a ball diff... but if you're planning of using it to "bash", I suggest starting off with the gear diff complete set.
You should probably get 30wt shock oil (just in case) and at least one set of aluminum rear hubs (the plastic ones are weak). For the hubs, ASC9864 is a direct replacement for the stock 0 degree plastic hubs and you'll need ASC7933 and ASC7935 to use them. I preferred the ASC9866s, personally, and a full set (9864-9867) is worth it for tuning options if you drive on a variety of tracks.
Hmm Bugger.
Ok so I am doing another order
Does anyone have the part number for the hex conversion kit? (if there is one?)
*EDIT* NVM I found it.
No planning to bash, purely going to be racing.
For the SC10 Hex Conversion do I require the new Hub Carriers or will the Hex Conversion work with the Standard FT kit?
what is the difference a change in the battery will make compared to a different motor?
for example: If I have a 10.5 motor and 7.4v 2 cell lipo compared to a 13.5t with a 11.1v 3 cell lipo or any combination.
I dont know how to ask this exactly, but what are differences that will be seen? Is there a chart that shows the different effects and comparison.
Is running a 11.1v with a 13.5t motor like running a 10.5t motor with a 7.4v battery? Does increasing the cell count have the same effect on the car as gonig with lower turn motor?
Thanks Brian, so..
9880 = SC10 Steering Block, Hex
9881 = SC10 Front Axle, Hex
9883 = SC10 Wheel Hex Adapters
9880 & 9881 Are for the steering and front wheels, whilst 9883 is the actual hex block for front and rear for the wheel to mount on too.
Do I have that correct?
I dont know how to ask this exactly, but what are differences that will be seen? Is there a chart that shows the different effects and comparisons?
On 3S the motor will not have to work as hard to reach the same speeds as it does on 2S.
However most SCT races (both club and national down here) are capped at 2S only. You will also be trading off speed for weight, which will directly translate to your handling.
You will have to go through your whole setup again.
A 3,000kv motor on 2s (nominal voltage) would have a top rpm around 22200
A 1,500kv motor on 4s would have the same top rpm but have more torque and use nearly half the amp draw.
If you decide to go the J-Concepts hexes, I would get the Factory team roll pins and also a package of wheel shims unless you buy the AE hex adapter kit to. Those include a set of standard pins and the shims.
Aluminium suspension arms? NOOOO. Only aluminium I use is what's stock on the factory team edition. Being new you need to spend your money on practicing at the track. That's the best way to sharpen your driving skills. Being new should get the kit and build it yourself so you get a understanding on how the truck works and how everything goes together. Nothing like building your own kit.
So aluminum suspension arms are a No No all together? Wouldn't it add more stability to the car?
Are there any aluminum parts anyone does recommend getting? Shock Towers? Bulkheads?
Any replies are greatly appreciated........
Just put New PL Gladiators, J concept Hex adapters and a Savos 1251MG servo in - my RTR SC10 now drives like a different truck
Whilst I'd like to get shocks and a few other bits I think if I do any more mods I may just buy a FT kit.
