SC10 Thread
#9812
With the Jconcepts blue rear hex's did you guys take the blue spacer off the rear? I have the spacer and the hex on currently and I can see some of the pin so im thinking that the spacer should come off.
#9814
#9816
i have searched this forum maybe i just such at searches but mine are brand new followed the instructions to a T and they are leaking. Seems the O ring on top is a little larger than it needs to be cause when i tighten down on the top dealio it seems to squueze the oring out the sides of the housing on top. How do i fix this buy a smaller oring? Can anyone post pics on what they did? Sorry im just a pic kinda guy.
#9817
#9818
When going off a team drivers setup and they are running big mod motors and such as 7.5 for example, if I'm running just stock should bi use the same amount of weight they are useing such as 3oz with the batt foam or should I scale down? Help needed
#9819
Does anyone play with roll center on the rear? If so did it help?
I currently have two washers on the front and two in the rear.
I'm looking to get more rear traction on turns. Already got .5 hubs.
TIA
TIA
#9820
yes it works that is something you need to test when your at the track,i never charged my batteries yesterday and i was there 2hrs before you all i did was make a 5-6 lap run and make a change
#9824
When my sc10 was clicking and I couldn't' figure out what it was, it turned out to be the dog bone slipping out of the hub just far enough to cause it to hit the opening of the hub with a loud "click" then slip off and keep spinning the wheel. It took me while to figure it out since it only happened to the inside wheel on fast inside turn with lots of grip.
#9825
It shouldn't make a difference if your running a 7.5T or a 17.5T motor. The weight on the different motors is quite similiar as far as I am concerned, the stators are just different turns, everything else is the same. I have a 10.5T motor and run near 3oz. of weight in my battery foam, and it works perfect.
