SC10 Thread
Old 04-26-2009 | 05:09 PM
  #901
i finally finished my SC10 here is the new body for it
jombo is offline
Old 04-26-2009 | 05:49 PM
  #902
LoonyRacing's Avatar
Originally Posted by jmonte23
Finally got to run my SC10 last night. Only one there against a field of slashes. The track I ran at allows 2.2 wheels and tires in the modified class which is what the slashes ran. I opted for the JConcepts goosebumps for the Sc10 and that was just the ticket. Won all three heats and the A main by a healthy margin. I ran the setup posted by PT Hill Top RC but did use the ball diff transmission. Powered it with a Tekin 13.5 and RS Pro speedo and SMC 5200 Lipos. Truck drove like it was on rails. Much easier to drive than my T4. Thanks to everyone in this forum for all the info needed to win the first time out..JoJo Monte
3 weeks ago same results here- The truck is awesome, Not one problem and I set a track record that is still holding. Also I ran a 17.5 and 3 slashes had 13.5's so I think driving is way more important than pure speed.
LoonyRacing is offline
Old 04-26-2009 | 05:52 PM
  #903
myrxseven's Avatar
Originally Posted by mcdonaldsracing
I've had all sorts of problems with mine. I've had the truck for about 3 weeks and I've only been able to run it about 1 1/2 hrs b/c it's been broken the whole time. It started with a bum 5700kv motor from castle(don't even get me started on their products!), which for about 4 days I was thinking was a slipper clutch issue. Then once I replaced the motor with a 4800kv excelorin, I stripped the idler gear after about 30 min of runtime. Well, I had a buddy that gave me his out of his spare kit so I could run in our first points series race at CapeFear raceway in NC last weekend and I ended up breaking an arm on my second practice lap. After the race, I replaced all the arms with RPM's from the T4 and GT2, and then I had a sun gear strip in the diff within the first 20 min of getting it back in running condition. I've always been an AE fan, but this thing has given me nothing but problems from the minute I opened the box(I too had to break the dremel out to fix a steering bellcrank clearance issue after completing about the 3rd step in the instructions). I guess I should have waited to buy about the 2nd or 3rd edition of this truck so they could have time to work out all the bugs
Not to sound mean or anyhting, but it sounds like you just threw the truck together skipping over some fine details.
myrxseven is offline
Old 04-26-2009 | 05:54 PM
  #904
trx450racer174's Avatar
I ran 8 packs through mine today on my track and have it very dialed in for hardpack high traction, As the track gets dry it is a different story. I am running the same setup as most except for a few small things.
trx450racer174 is offline
Old 04-26-2009 | 06:52 PM
  #905
aeRayls's Avatar
I you had to break out the dremel to fix the "steering issue" you built it wrong.
I always thought RTR's are just dumb and people need to build their kits, but after seeing how many problems people are having building what is a pretty simple kit, I now know why they are so popular.
aeRayls is offline
Old 04-26-2009 | 07:02 PM
  #906
Crawler's Avatar
I hadn't built an Associated kit in many years and IMO, the SC10 was an extremly easy build. No steering issues, I did some reading here on the board and found the typo about the rear camber link and took care of that, tranny went together w/o issue, no missing parts, no shortages of hardware, and the quality seems to be up to the usual Associated standards.
Only complaint is, I wish Associated would switch to the exclusive use of metric hardware.
Crawler is offline
Old 04-26-2009 | 07:08 PM
  #907
mcdonaldsracing's Avatar
I have built many kits in the past, and I'm confident that the build went just as instructed. The only thing I did that deviated from the instructions was to go with different fluids in the shocks and diff. I don't think any of these changes could explain all the problems I have had with this truck. When the truck actually runs it's a blast to drive, the problem is it won't run long enough without something breaking. I'm not bashing this thing either. I haven't been able to run it long enough. Most of the time it has been run in the driveway just to test it out and check for overheating issues that I've been having with it. Currently it's set up with a MM esc, a 4800kv excelorin motor, 87/16 gearing, and powered by a common sense 2S 5200mah lipo.
mcdonaldsracing is offline
Old 04-26-2009 | 07:19 PM
  #908
thanks for the helpful comments So you're saying that all the other people that have posted on this thing built theirs wrong also? I read through a lot of these pages last week and I saw numerous postings where others were having the same problems with the bellcrank clearance. Trust me, I pulled it apart and put it back together probably 5 or 6 different times before going to the dremel. Just b/c it says I'm a "tech rookie," doesn't mean that I'm a rookie to the hobby.
Old 04-26-2009 | 07:31 PM
  #909
CaptainHowdyt13's Avatar
Ok can anyone tell me if this is my diff doing this or something else?
Ran 2 heats, was grinding loudly when I take turns/have a lot of torque from a stop. I get to the mains and it's grinding REALLY bad. It got to the point where the truck was grinding ALL the time and very much losing power. I'm guessing the diff is either completely shot or it's something else. I havent taken it apart yet. If it's the diff, im tossing it in the trash and getting a T4 ball diff.
CaptainHowdyt13 is offline
Old 04-26-2009 | 07:35 PM
  #910
myrxseven's Avatar
I would recommend using the included 75t spur along with a 25 or so pinion. With the bellcrank and clearence issue comes down the the servo spring not being compressed fully.
Old 04-26-2009 | 07:45 PM
  #911
Hey aeRayls, did he build it wrong also??? Man, your problem sounds just about like mine. I pulled the diff out earlier and one of the sun gears had teeth that were ground down very badly. These trucks haven't even been out but for about a month, so should there really be this many of the same issues going on with them? Atleast the rebuild kit for the diff isn't too expensive (about $12 I believe), but again, why should we be having to replace all these parts when all of our trucks are so new?
Old 04-26-2009 | 07:52 PM
  #912
richardsonracin's Avatar
Raced my SC10 last night for the first time. I ran against 7 Slash's. I ran 2nd in all 3 heats and ended up winning the main. As the sun went down and the moisture came up, it was hooked! Handled and JUMPED great. I'm new to off-road, last night was my 2nd time to run off-road in over ten years and even then it was a few times. That says something for the truck! The sc10 was the only Corr truck that could clear the tripple after a big double. But, The Slash guys were running the stock 12t and i had a ss5800 geared way down. It was a handfull early on when the track was dry. Seemed harder to drive down the straights than in the corners. But that's just the tires not hooking up. but i'll take that over pin tires anyday. keep the realism to the class. It was very fun racing.
You definitely need to add some weight to the nose. I tried gold springs on the front and went back to the stock silvers. getting the slipper adjusted just right is half the battle on hooking it up.
richardsonracin is offline
Old 04-26-2009 | 07:54 PM
  #913
aeRayls's Avatar
I am saying 100% without a doubt that all those people built their steering racks wrong. Its a not so great design, and when you add first time builders(first time building that rack), you get problems. Once that servo saver is stripped once its done for life. It needs to be tightened all the way for best performance. Anything less than full tight will cause way too much slop with the stock spring. If its stripped or left way loose it will bind the steering.
aeRayls is offline
Old 04-26-2009 | 07:59 PM
  #914
You guys that jumped the gun with the dremmel on the "3rd" step of th ebuild should have waited until you mounted everyhting to the front of the chassis. Your steering space issue would have went away!
Please don't take offense. I'm not saying you did it wrong. I'm speaking from experience because mine rubbed a bit also, until i got it all bolted together....(and i had the saver bolt on tight!)
Old 04-26-2009 | 08:02 PM
  #915
KidAgain's Avatar
Whats your complete set up if you dont mind me asking.
If I looked at the rclive site correctly looks like FN CUDA got first today at OCRC raceway. CUDA post your set up cause I will be practicing there as soon as I build my car with many stops at trx450racer174 house if the invite is still open
Jake
KidAgain is offline
