SC10 Thread
Old 04-03-2009 | 10:44 AM
  #76
Suspended
Originally Posted by OTE_TheMissile
Just got off the phone with the LHS owner, I'm officially on SC10 Intergalactic Backorder. Early April...yeah, sure
Having pre-ordered = Mastercard
Getting placed on the perpetual backorder list = Priceless
Lightin' is offline
Old 04-03-2009 | 10:52 AM
  #77
Great writeup JD. Can you see any real difference between the SC10's trans case and the T4's? Rick Hohwart didn't even know the difference when I asked him But he did assure me a ball diff would fit in an SC10 and the bevel gear diff will drop right into a T4 or B4.
I didnt put a caliper on it, but there are some additional support molding /support webbing around the output shaft area of the SC10 Case. I am sure there are internal tolerance differences specifically for the gear diff area.
The SC10 Gear Case is part#9826
The B4/T4 Gear Case is part #9574
I believe what he meant was you could bolt the Gear (built with the 9826 case) or Ball Diff (use 9574 case) in either vehicle. The chassis attachment patterns for both case fit either vehicle. And probably the B4 as well.
JDCrow is offline
Old 04-03-2009 | 11:01 AM
  #78
TRU-RC's Avatar
So I finally recived my SC10 last friday thanks to the guys over at AE. I finaly got my electronics in and ran it for the first time in front of my house. This is my set up so far:
suspension- FT threaded shock bodys w/ ti nitrate shafts
Rear settings- stock
Front settings- 35 wt. oil w/ gold springs and #2 pistions
Motor- 17.5 orion vortec brushless
Speed-o- LRP Sphere TC spec
Servo- Futaba S9350
Reciver- Spektrum
Also addd: Ti turnbuckles
Cvd's
Tru-rc body wrap
TRU-RC is offline
Old 04-03-2009 | 11:22 AM
  #79
MDB
Suspended
Damn, now I wish I didn't waste my money on this Slash. Oh well, by the time I can afford the SC10, the trucks won't be on backorder anymore.
MDB is offline
Old 04-03-2009 | 11:49 AM
  #80
kdub's Avatar
Default Gear diff case
The SC10 gearbox is wider at the diff.... to accomodate the gear diff. Also it fits 10 x 16 mm bearings instead of 3/8 x 5/8 bearings from the GT ball diff.
To fit the SC10 gearbox in a T4 you also need to change to the SC10 rear chassis plate.
kdub is offline
Old 04-03-2009 | 12:49 PM
  #81
Suspended
This needs to be highlighted or sticked or something
because it is going to get asked about 3,000 times in the next 6 months.
Lightin' is offline
Old 04-03-2009 | 02:08 PM
  #82
wwoodruff
Guest
Posts: n/a
Thumbs up
Servo- Futaba S9350
Reciver- Spektrum
That truck looks tough, can you put a bigger pic up?
Cvd's
Tru-rc body wrap
Attachment 436640
That truck looks tough, can you put a bigger pic up. I bought mine to bash with, its going to get a new (bought them really cheap) Cobalt 9 double and a Novak GTX, should be a handful!!
Old 04-03-2009 | 03:46 PM
  #83
were can i get a tru-rc body wrap? thats awsome
charly71 is offline
Old 04-03-2009 | 03:47 PM
  #84
wwoodruff
Guest
Posts: n/a
Ditto.
Old 04-03-2009 | 04:00 PM
  #85
Cody Anderson's Avatar
well lets try something. all I see on slash threads are arguments....
SLASHES ARE REAL RACE TRUCKS/ sc10's are frail little radioshack knockoffs
Cody Anderson is offline
Old 04-03-2009 | 04:02 PM
  #86
wwoodruff
Guest
Posts: n/a
The SC10 has mudflaps!
Old 04-03-2009 | 04:06 PM
  #87
verticalpilot's Avatar
I just ordered mine from Tower, today IN STOCK.
verticalpilot is offline
Old 04-03-2009 | 04:07 PM
  #88
jimcoracer's Avatar
http://www.tru-rc.com/TruStore/pc/home.asp
jimcoracer is offline
Old 04-03-2009 | 06:14 PM
  #89
Suspended
Yeah, a few more months saving your allowance you should be good.
Lightin' is offline
Old 04-03-2009 | 06:17 PM
  #90
MDB
Suspended
Originally Posted by Lightin'
Then that explain why slashes are available now at PepBoys.
I have only seen Rustlers there.
MDB is offline
