SC10 Thread
Old 10-29-2011 | 11:31 PM
  #7726
wyd's Avatar
wyd
Tech Legend
From: Castle Mamba Max Pro. Feel its power!!!!!!!!!!
Originally Posted by rnoll98
+1
Had the Proline setup and bought the RS setup when it came out. Tons of slop in the Proline one. Partially due to their bearings (use the stock AE wheel ones instead) and partially due to the design/tolerances. The AE RS setup is much cleaner.
Its like Prolines axles are machines just a tad too small and fit loose in the bearings. I will be ordering the stuff I need to use the Associated setup this week thats for sure. All my other Proline products have been great so I'm disappointed that their hex setup sucks.
wyd is offline
Old 10-29-2011 | 11:52 PM
  #7727
Wild Cherry's Avatar
Tech Legend
Default Wilds 2w Sc-10
Here she is....
Thought I share with you guys my ride ....
Airtronics
Ae Xp servo
Lrp sxx v2
Reedy 60c
Team Trinity D3 8.5
Ballast under battery
graphite rear arm
Racer Edge .5 rear hub , 2.5 toe block
sway bars
Losi ball cups
and yes , it drives real good ....
Attached Thumbnails SC10 Thread-img0018.jpg   SC10 Thread-img0020.jpg   SC10 Thread-img0029.jpg   SC10 Thread-img0030.jpg   SC10 Thread-img0027.jpg
Wild Cherry is offline
Old 10-30-2011 | 05:31 AM
  #7728
Oso Negro's Avatar
Thumbs up
Originally Posted by Wild Cherry
Here she is....
Airtronics
Ae Xp servo
Lrp sxx v2
Reedy 60c
Team Trinity D3 8.5
graphite rear arm
sway bars
Losi ball cups
I really like it!
1) With your esc in the battery tray what did you rig up to keep the battery in place? Your pictures don't really show it.
2) what did you use for a ballast weight under the battery?
Ever since I saw Kinwald's setup with the esc in the battery tray I've been itching to try it too. It just makes sense to put it there. Your pics may have just motivated me to do it.
Oso Negro is offline
Old 10-30-2011 | 05:37 AM
  #7729
Looks sharp! May have to try those Losi ball cups next time I replace mine. Do you like them better then the RPM cups?
Quickstang is offline
Old 10-30-2011 | 06:23 AM
  #7730
idbdoug's Avatar
What is the largest/thickest 2cell Mah Lipo battery that we can mount in the 2wd SC10????
idbdoug
idbdoug is offline
Old 10-30-2011 | 09:12 AM
  #7731
mojoman81's Avatar
idbdoug
I stuffed a 8000mah 2s2p venom pack in mine . Basicly a 4 cell ' just take the half moon off the top of the rear hinge and put them on the bottom . That will raise the bat hold down and I took the thumb screws out of the front and use 3mm screws .
mojoman81 is offline
Old 10-30-2011 | 09:36 AM
  #7732
Tech Legend
Oso
I use lead roofing flash, very thin , weight is 4oz, fits the battery tray perfect.
ESC is mounted with servo tape & a extra thin pad between the battery & ESC...
Quick
Would of used RPM but my track was out of the color black , so I went with the Losi ball cups .
Either brand is stronger than the Ae ball cup .
Old 10-30-2011 | 10:15 AM
  #7733
The Joker's Avatar
Here she is....
Airtronics
Ae Xp servo
Lrp sxx v2
Reedy 60c
Team Trinity D3 8.5
graphite rear arm
sway bars
Losi ball cups
nice front swaybar...whos idea? can u take more pics of it?! have u ran it yet???
The Joker is offline
Old 10-30-2011 | 04:47 PM
  #7734
idrummerboy13's Avatar
Here she is....
Airtronics
Ae Xp servo
Lrp sxx v2
Reedy 60c
Team Trinity D3 8.5
graphite rear arm
sway bars
Losi ball cups
i have a stock spec i can throw in(v2) ill prob run a 10.5 motor inside, wondering why you put the esc behind the battery? more balance? and what setup you running, all your setups you recommend are dialed on the b4.1 thread lol
idrummerboy13 is offline
Old 10-30-2011 | 04:53 PM
  #7735
Originally Posted by Matt Trimmings
check it out here...
what the hell, this guys car is so cool, why! LOL anybody know were any of his setups can be found??!
(kinwald picture posted pages back, didn't put on the quote.)
i see graphite arms, losi springs?, modded sway bar setup, different shock mounts, different battery tray, blue speaker wire on speedo, wth!!! does anybody know were this stuff can be found
-and did anybody notice the screws on the chassis? the flat part...
Old 10-30-2011 | 05:54 PM
  #7736
hairymuffin's Avatar
This past wednesday Ty Tessman was at my track here in Beaumont Ca, for club racing with his sc10...I have a kyosho ultima scr which I love/hate....
Ty's car was so hooked up!!!!!! I have never seen a 2wd sc jump and have so much traction!!!!!! Guys he jumped every thing here at thunder alley!!!....I really am confused as to how his car was so dialed at my track? And the best of all he crahed that thing big time...He was doing back flips over the triples....He crashed a ton of times and never broke a part...Pisses me off because my kyosho broke a front bulk head and a reear plate the same nlght??? All I can say is wow!!! it was a cold night and my parts were brittle.....Is the sc10 that much stronger than the Kyosho?
hairymuffin is offline
Old 10-30-2011 | 06:18 PM
  #7737
the plastic is soft, when its cold they become nice, when its hot the can break easier to carbon parts replace them, a.e is great at meeting their customers midway, cheap parts and good choices.
Old 10-30-2011 | 06:40 PM
  #7738
Nice!!! I am really thinking of making the switch...After seeing tessmans car I was amazed, I know it was driver but his car was hooked and im really loving the durability
Old 10-30-2011 | 09:36 PM
  #7739
Here she is....
Airtronics
Ae Xp servo
Lrp sxx v2
Reedy 60c
Team Trinity D3 8.5
graphite rear arm
sway bars
Losi ball cups
What ride height are you running? 24mm?
gangstacoupe is offline
Old 10-30-2011 | 09:47 PM
  #7740
???E-Racer's Avatar
Im glad I have not went to 12mm Hex's yet. Another guy that runs them here
has tons of slop, even a fully tightend wheel it still wobbles like crazy...
Why change to hex anyway I like the pin type axels better myself...
AE has used them for years, why change something that already works?
???E-Racer is offline
