SC10 Thread
Old 09-28-2011 | 07:53 AM
  #7351
juzza99's Avatar
Originally Posted by 20 SMOKE
everyone has a different feel,i tried 10 first and didn't like it went to 5 and it was better then took it out and went to a ball diff
I see, ive only ever raced 1/8 gas ,but recently bought a sc10 and the ball diffs are quite a different thing for me,but i am learning about them now..
Cheers
juzza99 is offline
Old 09-28-2011 | 10:19 AM
  #7352
larsotra's Avatar
Default Turning
Would tighting the springs on the front make the car turn better??? or should it???
larsotra is offline
Old 09-28-2011 | 11:45 AM
  #7353
wrathfull's Avatar
Originally Posted by ShortCourseOnly
I would not be as concerned about upgrades in the beginning. The Radio provides a lot of tuning options so it would be a good idea. I use that radio. Getting used to racing and controlling you set-up should be your first focus. I would recommend the FT shocks at some point to help with tuning. The RTR comes with a very good starting point. As you improve I would recommend moving to a Stock SCT class with a 17.5 motor.
Why a stock truck? isn't there alot more people that would run modified trucks?
you lost me on the 17.5 motor, i was trying to find out the difference between them and how it effects your rc, can someone explain plz?
wrathfull is offline
Old 09-28-2011 | 11:48 AM
  #7354
Asharus's Avatar
Around here 17.5 is more popular, but there are some tracks that run Mod only, which is why I decided to have 2 separate trucks. However if a track runs both classes, I tend to run both trucks and skip out on 2WD buggy.
Asharus is offline
Old 09-28-2011 | 12:15 PM
  #7355
wrathfull's Avatar
Yeah i am not sure what the local tracks around here have, i know the SC 2wd is a popular class though.
Is 17.5 the speed of the motor?
Old 09-28-2011 | 12:18 PM
  #7356
Asharus's Avatar
17.5 is the amount of turns a motor has. the lower the number, the quicker the motor.
Asharus is offline
Old 09-28-2011 | 12:19 PM
  #7357
20 SMOKE's Avatar
do you mean adding a preload spacer or adding turns to the shock collar,shock location on the tower or arm will make it turn so will a spring change,post your setup
20 SMOKE is offline
Old 09-28-2011 | 12:42 PM
  #7358
larsotra's Avatar
Default Turning
Well i put it together just like the manual said and just added a little more camber and have the shock springs tightend down about half way on the threads
larsotra is offline
Old 09-28-2011 | 12:47 PM
  #7359
Matt Trimmings's Avatar
The only thing you are accomplishing by turning the collars up/down on the shock is adjusting ride height. To get a softer/stiffer feel you need to change springs which could lead to changes in oil/piston as well. What are you trying to accomplish? The #1 thing right away is to make sure that you have the correct tires/compound for your track.
Matt Trimmings is offline
  #7360
20 SMOKE's Avatar
FT kit,i dont know what every truck has i start with a stock setup and make changes and as of now i run 3 hole pistons so mine is no were close to a kit setup anymore
20 SMOKE is offline
Old 09-29-2011 | 01:37 PM
  #7361
larsotra's Avatar
and suspension rebound...right which incase puts more downdorce on the front arms planting the front tires into the gournd more
larsotra is offline
Old 09-29-2011 | 02:58 PM
  #7362
Oso Negro's Avatar
Any secondary effects that tightening the springs down has is not something you need to be focusing on.
Everything on a vehicle has a primary purpose. Learn what those are and focus on that. You'll do a lot better
I highly recommend this following thread it completely transformed my understanding of how to tune an RC car:
TUNING WITH CAMBER LINKS
http://www.rctech.net/forum/electric...ber-links.html
Oso Negro is offline
Old 09-29-2011 | 03:45 PM
  #7363
Zac_with_no_K's Avatar
Exclamation
What do I have to do to make a Gens Ace hard case LiPo fit in the battery compartment?
I have a RTR SC10.
Any advice helps,
thanks
Zac
Zac_with_no_K is offline
Old 09-29-2011 | 06:00 PM
  #7364
Led Finger's Avatar
Cool SC trucks just not for me
Looking to turn my SC10 into a T4. Anyone do this? Parts needed? I think they cant be much different.. looking for some insight please
Led Finger is offline
Old 09-29-2011 | 08:53 PM
  #7365
The Joker's Avatar
They share a lot of the same parts, its mainly about just removing the front & rear bumpers.. even tho the chassis looks the same the T4 chassis is a bit shorter!
The Joker is offline
