SC10 Thread
#5493
I'm running one. Gear it between 20-78 and 24/78, use 80-100% punch control, set your slipper for about 15' of squeal, and have fun.
#5496
I tried running a 4th hole in my tower tonight. I was only able to try it out on the street, but I think I like it. I'm going to leave the shocks there until the next race.
#5497
Hey Chris, I'm about to rebuild my SC10 to your specs. How far did you back off the slipper? Fully tight and then a quarter turn or something else?
#5498
Here's my latest setup sheet if you're interested. It's biased towards rear traction, but still turns pretty well.
https://docs.google.com/viewer?a=v&p...YWVjYzlj&hl=en
#5500
Chris, 15' to me seems like a ton of slip. I don't know your track, but isn't there any sections where you have to accelerate quickly to clear a jump? At my home track there's one section where there's a hairpin followed by a quad and you gotta get up to speed fairly quick to do a double double. Every track's different i know but 15' seems a lot.
But, the more I think about it, I guess your motor would be throwin down gobs of torque which I guess may cause your slipper to be screaming for mercy even though it's still set fairly tight.
#5502
Not to mention the fact that pads will be shot. I've never seen a melted spur but that to me would be the way to do it. Old news ~ if you need more than 2-3 feet of slipper, use less go finger or you're gonna wreck stuff.
#5503
Sorry, I should have mentioned that I've been setting my slipper on pavement with stock tires. With this setting I'm getting about 6' on a blue groove track with SS Enduros.
Yes, this motor makes a boat load of power. I basically set the slipper as tight as I can without breaking the rear end loose at will on the track.
Use Punch Control to mellow it out especially if you're using lower gearing(9.5:1 or higher).
#5504
I'm using the V2 slipper and I have it set about 4 turns in from flush. With the V1 you're going to have to crank it and then just back off a hair.
