SC10 Thread
Old 01-13-2010 | 12:54 AM
  #3826
smokinu's Avatar
i picked up a ft t4 and now am running a ft sc10
so it now has ft trans with ball diff and blue motor mount.
ft turnbuckles with rpm ends
cvds
ft threaded shocks F/R
and man has this truck picked up in its handling department.
smokinu is offline
Old 01-13-2010 | 09:26 AM
  #3827
Matt M.'s Avatar
Administrator
possibly i missed it, but does anyone have the part number for the spacers that go in the gear diff to fix the grinding..
Matt M. is offline
Old 01-13-2010 | 10:23 AM
  #3828
Joel Lagace's Avatar
Originally Posted by T-BirdJunkie
Has anybody had any issues fitting zippy 2s 4000mah hardcase lipos in their SC10?
I run a similar pack. Full forward and i had to dremel out the strap a bit near the top above the pos and neg holes
Joel Lagace is offline
Old 01-13-2010 | 01:52 PM
  #3829
T-BirdJunkie's Avatar
From: Norwood, OH...and CCRCR and The OhioRCFactory
Thanks Joel. A little trimming on the battery strap isn't bad, just glad to hear it fits in the tray width-wise
T-BirdJunkie is offline
Old 01-13-2010 | 03:56 PM
  #3830
smokinu's Avatar
the sc10 is a great truck with the right parts!
man the ball diff, ft shocks, and the proper set up this thing just plain hauls but on a track!
smokinu is offline
Old 01-13-2010 | 05:19 PM
  #3831
ollie 45's Avatar
Originally Posted by smokinu
i have a 5700 kv and run it 17/84 she runs about 140 after a 7min main.
spot on on anytrack.
No problems here from any of mine, you will have to dremal the battery a bit to get a connector to properly fit but not much.
i run the zippy 5.2s now still no problem.
I have the same 4000 pack but don't run it because of the top posts. I do however have one of the 5.2 packs and all I can is that pack is AWESOME. A little tight for the battery stap but tons of power out of it.
ollie 45 is offline
Old 01-13-2010 | 06:33 PM
  #3832
I called customer service at Associated and they sent me some shims.
laedco58 is offline
Old 01-13-2010 | 06:52 PM
  #3833
smokinu's Avatar
yeah the 5.2 packs are GREAT lots of punch and i think i am getting like 30 to 40min run times.
smokinu is offline
Old 01-13-2010 | 10:59 PM
  #3834
I've got two of them and the only problem I ever had was in a hard crash one of the banana plugs came lose and cost me a couple of laps. Otherwise they are fine, and no different from the big-name brands with banana plugs in that respect.
Run one in my SC10 every race day.
markd469 is offline
Old 01-14-2010 | 11:57 AM
  #3835
ade's Avatar
ade
Electric newb here.....where do you buy these packs or the 5.2 pack?
ade is offline
Old 01-14-2010 | 05:19 PM
  #3836
R/C Tech Elite Member
Try and make your connectors like this, I had the same problem--along with the bullet (banana) connectors becoming loose and sloppy and losing a good connection. After I re-soldered them at 90* I have never had either problem again...
flame56mx is offline
Old 01-14-2010 | 07:17 PM
  #3837
ollie 45's Avatar
]Electric newb here.....where do you buy these packs or the 5.2 pack?
http://www.hobbycity.com/hobbycity/s..._Car_Lipo_Pack
ollie 45 is offline
Old 01-14-2010 | 07:25 PM
  #3838
I am confused--did you mean to ask Would you buy? If so, the only difference between the 4000 and the 5.2 (5200) will be runtime, the 5.2 has a little more "C" rating that may give a tad more punch also...
Old 01-14-2010 | 07:43 PM
  #3839
ollie 45's Avatar
The other guy "electric newbie" asked where to buy the lipo's, so I quoted it and answered his question, HobbyCity, but it didn't do the quote for some reason. I looked after I did it and it did look kind of funny.
ollie 45 is offline
Old 01-17-2010 | 12:00 AM
  #3840
z50king's Avatar
I ran today at wcrc and felt like i was killing with my 13.5, was beating all the stockers and running with sc trucks with bigger motors. got nothing on the 4 wheel sc's though
25 weight oil front and rear. silver rear, green front. 1 limiter moved from inside to outside on the front shocks. black sway bar kept it from traction rolling on accident. bowties on beadlocks front and rear. 13.5 geared at 26/84, got up to 150f
z50king is offline
