SC10 Thread
Old 04-11-2009 | 09:28 PM
  #316
F N CUDA's Avatar
Originally Posted by PartTime
An easy way to remember it is on and off power. The more caster you have the more off power steering you have. You can carry throttle into a turn so going more caster makes the push worse even though your going into the corner.
DK
So if I let off or brake coming into the corner it'll dive in more with 30 degree than 25 right?
If I let off then punch it into the corner it'll push more with the 30 degree caster block, right?
Originally Posted by rcmark24
Wow hate to hear all the problems. Just finished mine with no glitches but I've been putting Associated kits together for way too long! No steering problems and no diff problems. I'm also using the black grease like they say to do! I would like to hear alittle more about the inserts though. I'm mounting the J Concepts Goosebumps instead of the factory tires and was going to put the AKA foams in but this truck will be run on outside tracks only. They may be too firm but I'm afraid the stock are too soft. Anyone heard anything?
I put in AKA med (only ones they make for now) and they are very, very hard but the kit foams are way too soft, at least for my indoor smooth track.
The 1/8th scale nitro guys say the AKA foams are best when broken in after a set or two of tires and thats after a 7 1/2 pound 4wd firebreathing buggy beats them for 2 sets of tires.
I'm guessing my SC10 will never be able to break them in but they worked ok for me last nite. Maybe we'll hear that another foam from 1/8 scale will be a little less firm and work better for our trucks?
I think the AKA was recommended and used since it is said to be the best 1/8scale foam available, for 1/8 buggies tho. Just a thought.
Originally Posted by Dragonfueled
Anyone notice that there outer axle hubs rub the rear control arm when the suspension is hanging? Or did I do something wrong?
Mine rubbed too, I checked to be sure the shock ends were screwed on completely since leaving them partly screwed on would leave the shocks too long and allow the arm to drop too far. They still rubbed a little and I didn't want to add more shims inside the shocks so I just removed a little material from the cross brace on the arm.
Originally Posted by verticalpilot
No, the pinion on the motor depends on the speed of the motor and the track. I'm going to run stock (13.5) and start with 24 or 25 as stated in the manual (actually 26 is what's stated).
I started with a 26 pinion on my Novak 13.5 and it thermaled before I even got around to checkin the temp, about 1 or 2 minutes into a practice run.
worked my way down to a 23 and twice it thermaled at about 8 to 10 minutes of consecutive practice runs. It was still really fast so I raced it like that last nite.
Originally Posted by charly71
hey i just got mine built and i rolled it on my table and it will only roll about a foot and then the wheels will kinda bind or lock and skid across my table. there are no electronics in my truck. is this normal? from my past buggies/truck im thinking not. anybody?
As mentioned above, the only thing draggin on mine was the rear axles against the cross brace on the arms. Grind the arms down a little or add more shims inside the shocks.
F N CUDA is offline
Old 04-11-2009 | 09:31 PM
  #317
verticalpilot's Avatar
Originally Posted by F N CUDA
I
Thanks for the input, I may start with 22 or 23 then.
verticalpilot is offline
Old 04-11-2009 | 09:41 PM
  #318
Finished my build today, but there were 3 rear body posts and only one front...guess I'll have to give ae a call.
Krio is offline
Old 04-11-2009 | 10:04 PM
  #319
trx450racer174's Avatar
Built my diff tonight all went well and no crunchy diff, Have the shocks left to do and the paint scheme is laid out on the body to shoot tomorrow also.
trx450racer174 is offline
Old 04-11-2009 | 10:05 PM
  #320
F N CUDA's Avatar
Got pix up finally.
Can check out the weight placement that I used to get it feelin pretty F N good. 3 oz total weight added.
4 x 1/4 oz squares on the front bumper skid plate
2 x 1/4 oz on each side of the front of the battery tray standing up
2 x 1/4 oz on each side at the rear of the chassis, look by the antennae.
Attached Thumbnails SC10 Thread-no-stickers.jpg   SC10 Thread-stickers.jpg   SC10 Thread-weights.jpg   SC10 Thread-front-weights.jpg
F N CUDA is offline
Old 04-11-2009 | 10:09 PM
  #321
Got pix up finally.
what motor you running Cuda???? and NIMH or LIPO.
Old 04-11-2009 | 10:24 PM
  #322
F N CUDA's Avatar
Motor is 13.5 Novak and it feels like a freakin modified motor in this thing.
I run Lipos, 5000 Reedy and 3200 Orion.
F N CUDA is offline
Old 04-11-2009 | 10:29 PM
  #323
jiggyb's Avatar
Sorry to ask again but...............
sidewinder 4600 arrives Monday.........any gearing advice?
jiggyb is offline
Old 04-11-2009 | 10:55 PM
  #324
I gotta say, I like sc10 heck of a lot better than slash. sure the slash came pre-assembled, but tuning this thing will be easier than slash. All that 'spec' rules and what parts you can't use...
AE quality is very good I must say. Many have some small issues, but no maker is perfect.
Old 04-12-2009 | 01:52 AM
  #325
NielsVV's Avatar
Your 13.5 motor is a brushless one? Or do you mean with this 13.5, the number of turns this motor have (brushed)?
If its a brushless one, do you know how much kv this thing have?
I have here an orion element 10.5 brushless, but I think this will be way to fast for the sc10.
NielsVV is offline
Old 04-12-2009 | 05:29 AM
  #326
rob martin's Avatar
looks good so far.
rob martin is offline
Old 04-12-2009 | 06:07 AM
  #327
PartTime's Avatar
Correct.
DK
PartTime is offline
Old 04-12-2009 | 07:04 AM
  #328
I just set mine up with a 18 tooth pinion and the big spur. I'll try it in a few hours and see how it goes. I'm thinking 4600 kv is more then whAt everyone is running so hence the 18 pinion
Dragonfueled is offline
Old 04-12-2009 | 08:02 AM
  #329
Suspended
I bought mine Friday night and was up until 3 in the morning building. I can't wait to run it at my local track next weekend.
phathedrc18t is offline
Old 04-12-2009 | 09:03 AM
  #330
blade329's Avatar
R/C Tech Elite Member
I'm still building mine, but I had a chance to run my friend's SC10 at HRH this weekend. While it was fun to drive, it did not blow my sox off. With a stock motor, it was quite fast. It was definitely faster than a stock Slash and handles differently. I think you would have to be nuts to put anything more than a 19T motor in this thing. Even a 19T will be difficult to manage. It wont be able to handle the power, period. It's a great truck, but the hype factor with this thing is way over the top.
blade329 is offline
