SC10 Thread
#3047
o.k. can anyone help me out....first of all when I turn the wheels full left or right an hold it there the steering has so much slop I can't imagine where the truck will go(this is brand new rtr) also anylthing I can do to adapt the slash wheels to fit on the front of the SC10? I have a brand new set of goosebumps I wud like to use(mounted on slash rims)....what about diff lube ? I ran 30000 in my slash an worked well...I installed 17.5 bl and wud like to run a pinion larger than 22 but won't fit....cut out the adjustment slots but motor hits the motor guard and won't allow for larger pinion....never owned a associated always been a losi guy....first looks I'm not very impressed with the SC10 but I will give it a chance...thanks for any help
#3049
All 1/10 off-road race vehicles have that "slop" you are referring to at full lock. It doesn't affect the car on the track; the steering bell cranks can only go so far and the turnbuckles allow the wheel to pivot a little extra at full lock once max. steering throw is reached. Just run it and you'll see what I mean
Just search through all the various SC10 threads and you;ll find the info about installing Slash hexes. I know it's been done.
You can install the optional spur gear to achieve the gearing you want.
.Just search through all the various SC10 threads and you;ll find the info about installing Slash hexes. I know it's been done.
#3052
This conversion is going to be a little bit tricky you will have to be a little bit more creative on this one. I'm thinking you will need a sleeve since the associated front wheels have a smaller diameter shaft.
#3053
Well I went racing tonight. First encounter with a blitz. I will say this, they are going to be some serious competition for the SC10. He had a super hot motor in there that was way faster than me. I have a 7.5 so mine is not slow. He was running those stock tires and it had more traction than I have seen on a SC. It was pulling wheelies effortlessly he had so much traction. I think I want to try some on my sc10. I ended up 5th in the A main tonight. Not my best finish but my lap times were consistent so I cant complain too much...
#3056
[QUOTE=TfnG;6501645]17.5 gearing should be 75/25-28. Ur kit should have came with the 75t spur.
My RTR didnt come with optional spur...think its only the kit version that does.
#3058
#3060
I have ran bowties and am currently running goosebumps. Right now they are the best tire I have tried so far. I will be getting my hands on some of those Blitz tires though. I couldn't believe how they hooked up.
My gearing is 87/24, motor temp after like 15 min are at 140. I think I have my radio dialed back to 130 on my DX3S
I dont like the beadlock wheels too much. They weigh 2X what the Rulux do. And I was always popping a darn bead with those things. They would be good for a less powerfull motor
Last nights race I ended up getting 22 laps. Best ever on the track was 23. That darn HPI got 24. The truck doesnt seem any better but that traction made all the difference.
