SC10 Thread
Old 10-22-2009 | 11:19 AM
  #3061
z50king's Avatar
Originally Posted by whipnet
Wow, the kit actually had something that the RTR didn't? I felt so ripped off when the RTR came out for just $20 more.
Doesn't the kit come with a full spacer kit for the shocks? The rtr doesn't. Using the radio system for a month was worth the extra 20 dollars, and the motor and esc are still holding up well
Originally Posted by R-E-A-P-E-R-
I dont like the beadlock wheels too much. They weigh 2X what the Rulux do. And I was always popping a darn bead with those things.
I had the inside of the tires bead pull out once, but that is it. Don't forget to buy new locknuts every few races so you dot ruin the pin carriers inside the wheel
when I first saw my bead locks sitting under the truck on the start straight i thought it looked like some goth rim, because of the black and the shiny spots
z50king is offline
Old 10-22-2009 | 08:02 PM
  #3062
R-E-A-P-E-R-'s Avatar
nah, no more bead locks for me
JC for me
R-E-A-P-E-R- is offline
Old 10-22-2009 | 08:10 PM
  #3063
RcRacing4Ever's Avatar
I like they way the beadlocks look on the truck...I think its just to much weight, Relux rims for me with goosebumps on them seams to work best for my style of driving
RcRacing4Ever is offline
Old 10-22-2009 | 08:19 PM
  #3064
Yeah I have had great luck with the goosebumps. And they last longer for me than the BowTies
Old 10-23-2009 | 12:33 PM
  #3065
newbie2's Avatar
Default drive shafts coming out
my new SC10 seems to be having a problem with the dogbones coming out when up on a stand and while testing the motor..makes a awful noise and the rear wheels start jumping u-p an down...I installed the spacers in the tranny so I know thats not it. an the truck is brand new..anyone else experiencing this problem??
newbie2 is offline
Old 10-23-2009 | 12:40 PM
  #3066
balistic's Avatar
did you install the limiters in the rear shocks?
balistic is offline
Old 10-23-2009 | 01:16 PM
  #3067
z50king's Avatar
The rtr comes with two black limiters on the shaft inside the shock. But the kit direcions don't talk about doing that
z50king is offline
Old 10-23-2009 | 01:27 PM
  #3068
xraysteve's Avatar
My kit instruction show 2 spacer in the rear shock and 5 in the front.
xraysteve is offline
Old 10-23-2009 | 01:58 PM
  #3069
The goosebumps seem to be the best tire on our indoor track, proline m3 works well but loose traction at the end of 5min run
racer511 is offline
Old 10-23-2009 | 02:28 PM
  #3070
MooseDrool's Avatar
Has anyone tried racer's edge 1º rear toe blocks? What is stock?
MooseDrool is offline
Old 10-23-2009 | 05:16 PM
  #3071
Dont know the rules on your indoor track on mine i have taken goossbumbs and made them ghost pins almost slicks and they are very good. Moose the hubs are just like ones we run on are t4 lights setup. You should have your t4 and sc10 close to the same setup if u have any questions ill be there sunday.
SikKustomz is offline
Old 10-23-2009 | 10:03 PM
  #3072
MooseDrool's Avatar
ok, are you running them?
Old 10-23-2009 | 10:51 PM
  #3073
running the 1 degree ..no, Im using the 2 degree losi hubs
Old 10-24-2009 | 12:38 PM
  #3074
OG RC 10T's Avatar
Try putting a couple of red shock o rings in the transmission side, and a couple of red o rings in the other side. It will help keep the dogbones centered and will keep them from poping out.
A trick we used to do on the old 10T and Gold pans was to take the spring out of a click type, bic pen, and place that in the drive axle side then put the dog bone in place. It kept tension on the dog bone and also helped prevent them from poping out.
I changed my bones to CVD axles, and though it was a pretty penny to do so, it was well worth the investment.
OG RC 10T is offline
Old 10-24-2009 | 07:04 PM
  #3075
tom_chang79's Avatar
Better than those O-rings. I use nitro fuel tubing. You can make shock limiters, spacers, cushions for outdrive/dogbone, and so much more...
Fuel tubing is one of the most universal things to have in your toolbox...
tom_chang79 is offline
