SC10 Thread
Old 08-22-2009 | 09:26 AM
  #2356
OG RC 10T's Avatar
Originally Posted by koolwhipman
New Slash tires will fit the SC10 wheels fine. When the Slash came out, both the inside and the outside were 2.2 diameter. They soon quit that and went with the 3.0 and 2.2 that are used on the Slayer. You shouldn't be able to find the 2.2 / 2.2 one new in a package anymore, it was a while ago and they got bought out pretty quick. I've only seen them on a Slash that I just got some goosebumps for my SC10 and the biggest difference it made was making it illegible for the local box-stock class. Time to get some AE tires as well...
Though by changing the tires, it wouldnt be box stock class. The differnt tires are a huge difference and those with stock tires, would be at a great disadvantage.
OG RC 10T is offline
Old 08-22-2009 | 09:34 AM
  #2357
RodneyB's Avatar
Originally Posted by CBHVR6
what lipos are you guys running in yours because i was test fitting my smc lipos (motor/esc didn't come yet) and because of where the wires come out, i can't close the hinged battery hold down
I have had the SMC 5200 40c batteries in mine and it was close, but I was able to close the battery cover without modification.
RodneyB is offline
Old 08-22-2009 | 09:43 AM
  #2358
OG RC 10T's Avatar
I just bought the SMC lightning volts hard cased lipo, 5200 mah 24c, and the wires come out on the upper left side. The battery was a little tall but I adjusted the mounts for the battery tie down and for the fastners and it fits in there perfectly. The wires do touch the battery hold down, but it does not rub, because the battery does not move, it is very secure.
If your worried about it rubbing or being to tight, take a file or dremmel and notch the brace.
Old 08-22-2009 | 11:32 AM
  #2359
thanks for the quick respond on the tires issu so i'l order them to bash around will last longer than goosbump. any one have tried them on the sc10 to know if they are good for bashing?
budfreak is offline
Old 08-22-2009 | 11:42 AM
  #2360
OG RC 10T's Avatar
They are good for bashing, as long as you stay off pavement. Pavement will chew up any tire rather quickly. Your stockers will be good for pavement though.
Proline makes a Switch tire in 2.2 Its an SC tire and I am currently using on a 10t and T4. They wear well and not excessivly on pavemnt, They are one of the better all around basher type tires that I have owned.
If you can find them in 2.2/3.0 size, as the sc rims are, they will be a direct fit. Other wise you will need 2.2 rims.
The only 2.2 rim that I am aware of that will fit the back and have the proper off set is the rear wheels from the J82, though I am sure there are others out there.
Old 08-22-2009 | 12:37 PM
  #2361
hey og rc 10t thats funny your talking of the switch tires just order them before seeing you post though they would be better then the slash one to bash around and will try some proline split six beadlock in the rear hate gluing tires will see if it's good or not
proline switch tires m2 #1078-01
proline split six beadlock #2717-02
is that sound good for you?
thanks
budfreak is offline
Old 08-22-2009 | 01:34 PM
  #2362
CBHVR6's Avatar
Alright thanks, they are the ones I have
CBHVR6 is offline
Old 08-22-2009 | 03:23 PM
  #2363
Crawler's Avatar
I have several lipo packs that I run in my SC10 according to what I'm doing. If were just playing around on the track to kill time, I run my PolyQuest 2S 25C 6000 MAh pack. I get great run time from it, but I had to lose the stock battery strap(no biggy, just made my own)to run it do to it's length. For heat racing I have a few FlightMax 2S 25C 4000 mAh Hard packs and for mains, I have a couple FlightMax 2S 20C 5000 Mah packs for the mains. All of they fit w/o much issue and w/ the stock battery strap removed, I can move the battery forward and back in the tray to help w/ handling.
Attached Thumbnails SC10 Thread-shock-build-sc10-028.jpg   SC10 Thread-shock-build-sc10-017.jpg
Crawler is offline
Old 08-22-2009 | 03:59 PM
  #2364
OG RC 10T's Avatar
thanks
Sounds good to me. Thanks for the part #'s. I plan on getting the split 6's also but in due time. The lhs only had ae ones and i wanted to put it on the track quicker than 5 to 7 days waiting for the mail.
Old 08-22-2009 | 08:29 PM
  #2365
so crawler how does it react with the lipo farder back does it change a lot?
no trouble for parts number on the beadlock hope they will hold the tire on the wheel
budfreak is offline
Old 08-22-2009 | 09:59 PM
  #2366
Crawler's Avatar
It really helps plant the rear end, but the front floats a bit to much for my liking. I run it centered in the tray. Seems to be a little more neutral IMO.
Crawler is offline
Old 08-23-2009 | 01:00 AM
  #2367
njmose1's Avatar
i ended up ditching the battery strap and put on some velcro instead. allowes you to move the battery around easier. so far after a couple races i've found that having it centered like Crawler said works the best so far.
anyone have any experience with the Pro-line split six wheels? do they hold the tire in there or do they pop out easily?
njmose1 is offline
Old 08-23-2009 | 09:22 AM
  #2368
anyone running a novak havoc esc in their sc10. was thinking of getting the new truck and already have the esc, but it looks to be a little narrow on the chassis. just wondering if the esc will fit ok w/o hanging outside the chassis. thanks.....
nitro0619 is offline
Old 08-23-2009 | 09:27 AM
  #2369
will g's Avatar
Alright guys i need alittle help... i bought all the stuff to do the gt2 set on the rear arms and i got it all together finally and i put the shocks back on and they bottom before the chassis does. i know you cant have that but what did everyone elase to do fit that did the mod. also if i put the shocks inboard on the tower and arm how would it effect the handling and such thnx Will G
will g is offline
Old 08-23-2009 | 09:36 AM
  #2370
RMDesigns's Avatar
I have the novak gtb in mine, I think they are the same sixe. It fits in the chassis fine, I don't think you will have a problem.
RMDesigns is offline
