HoBao Hyper 9E thread >
Old 03-01-2011, 04:30 AM
  #3676
707
Default Brace Pic
here are some pics of the Ve8 brace on a Bump Edition. It does fit and I'm sure it will work, BUT! Anyone who has driven one of these cars cannot argue that is quick right out of the box! There are also alot of thimgs to consider when re-mounting your servo, like,body clearance, range of motion for your servo arm and servo link etc... I personally don't think its worth it. The car was designed with flex just like the rc8be, and they both work really good!HoBao Hyper 9E thread-pict0090.jpg
707 is offline
Old 03-01-2011, 07:25 AM
  #3677
Daebech2475's Avatar
Trader Rating: 58 (100%+)
That PBS kit looks like a must have. Thanks for the pics, and please post when you're aware of availability.
Daebech2475 is offline
Old 03-01-2011, 04:11 PM
  #3678
kufman's Avatar
Originally Posted by 707
The stock Hot Bodies Ve8 front brace fits will fit like a glove.....drill one hole.
Did you use Tekno servo mounts?
Yes, I used the Tekno servo mounts. Only 1 screw per end but it is still very secure.
I didn't even think about the VE8 brace. Might be something to look into.
kufman is offline
Old 03-01-2011, 05:04 PM
  #3679
danulmer18's Avatar
Mister g who is the Aus importer for Hobao? Only place I can find Hobao parts is OCR in Darwin. Where do you get your stuff?
danulmer18 is offline
Old 03-01-2011, 06:11 PM
  #3680
Cappy's Avatar
Trader Rating: 16 (100%+)
Will this batt fit in the stock tray ?
http://www.amainhobbies.com/product_...C-148V-4200mAh
Cappy is offline
Old 03-02-2011, 11:34 AM
  #3681
-R2-'s Avatar
If you have a video fo your OFNA ride on Youtube please send me the link so I can review and maybe post it on our OFNAfan.com website. We wanna have bashers,crashers and racers in their OFNA's tearing it up. Bring it, Titans, DM-1's, GTP's, Dominators, Pirates or even old school Colts if you got a vid send it to me at [email protected].
-R2- is offline
Old 03-02-2011, 09:19 PM
  #3682
eric3272's Avatar
Trader Rating: 14 (100%+)
If anyone's looking, I've got an H9E roller and parts lot in the for sale forum:
http://www.rctech.net/forum/r-c-item...ml#post8729505
eric3272 is offline
Old 03-03-2011, 12:34 PM
  #3683
went to my hobao dealer today to ask about the pbs, saw his son doing 2 second faster laps with it installed. he said it was much smoother in the corners. he has only received one system for sale to the public, cost me 120 euros for the kit and 35 for a set of front cvds he said i needed. will have it installed an run by end of the week an will let you guys know what i think of it. excited to try it as his sons car looked soo planted an in general i like pbs over c hubs.
flumpy is offline
Old 03-03-2011, 01:58 PM
  #3684
Thanks for the update. Eagerly waiting the arrival of this pbs system, as I would much rather have a pbs system on my 9 than the current c-hub system. Seems to handle overall better for my other rides, am sure it would be awsome for the 9e. Hopefully will be on NitroHouse (or anywhere) before the summer outdoor season for the NorthEast. I'd like to hear how they work for ya.
Old 03-03-2011, 03:26 PM
  #3685
Trader Rating: 73 (100%+)
One other thing I forgot to mention about the BPS.
Drive shafts are now the same as the rears so no need to have 2 different types.
I think that's good news given they are one of the most expensive individual spares you probably have in your kit.
mister_g is offline
Old 03-04-2011, 06:11 PM
  #3686
Cappy's Avatar
Finally got my Hyper 9e !! I cant wait to get it on the track
Cappy is offline
Old 03-05-2011, 08:27 AM
  #3687
Trader Rating: 43 (100%+)
will the proline crowd pleaser body fit with the 3.2mm bump chassis and teknomud guards.
http://vmhfv.fqdqc.servertrust.com/C.../pro327900.htm
aceinthesky is offline
Old 03-05-2011, 08:50 AM
  #3688
i'm working on converting a ofna x1 cr to electric and looking at using a 9e motor mount. I was wondering if somebody could measure the bolt pattern on the chassis for me to see if it is similar to my x1.
p.s. i have seen the rc monster mount already but it's too expensive for me.
h2odude is offline
Old 03-05-2011, 11:39 AM
  #3689
el Bourlando's Avatar
Yes, the Pl body will work. I have used it on the H9 2.0 buggy, with the 4x4 chassis. It is 4mm longer, whereas I believe the Bump E's are 3mm longer than stock.
Where it shows up as far as mounting is at the rear. It was lengthened behind where the mudguards end, near the pivot block. It is best to shim the rear body mount forward a bit. This allows more lexan material around the body hole and it will last longer. I used some spare wheelbase spacers and a longer screw to space the mount forward. I have found it much easier to mount the body to the chassis first and then do your normal body prep before painting.
Another thing to keep in mind though is what type/size of battery you are using. Most will not be an issue but with some of the "brick" type 5 & 6s packs with very high mah count, it may get tight around the battery. I personally use a 5s 3800 that measures 36x39x14omm and weighs 490g with no clearance issues. Either in the forward or back position withthe Jconcepts body and now with the Jconcepts losi Punisher body.
The Punisher body does require extra modification to get a proper fit. Which inlcludes lowering the front and rear mounts, along with moving the rear mount forward. And some extra trimming around the front and rear bulkheads. Again I would suggest mounting and trimming this body prior to painting for easier fit and you dont mess your new paint up.
el Bourlando is offline
Old 03-06-2011, 11:39 AM
  #3690
JCapps's Avatar
Default Drive Shafts
Does anyone know where I can buy the new black front driveshafts for the hyper 9e? My universals bent and I have been looking everywhere for replacements. Thanks!
JCapps is offline
