HoBao Hyper 9E thread
#244
looking to get started in 1/8e soon, looks similar to what i would like to build, what kind of run times are you getting with this setup? I need to get at least 20 minutes . . . will be running with the nitros
#248
Tech Legend
some hop ups on the way for the vehicle (thanks FMLinero for finding the link):
http://www.neobuggy.net/modules/news...p?storyid=6773
#252
Tech Legend
Here is the setup I plan to try next on my vehicle lesss batteries, big thanks lbckevin for sending me his setup:
What kind of runtime are you seeing with the 3300mah 4S batteries?
I am using the stock out of the box setup with the following changes....
35wt Associated Shock Oil front and rear.
White front springs ( middle)
Blue rear springs (softest)
I run Heperion 4s 3300 mah batteries using a Tekin RX8 speedo with a 1900 kv motor.
I am running the new J Concepts Gold Sevens tires.
For the diffs....all using Associated Oil
Front ....5000wt
Middle ...5000wt
Rear ......3000wt
I run indoors on a super high bite track. Check out Liverc.com and look under Orange County raceway tomorrow night...you will see 5-6 Hyper 9's and a few RC8's as well.
Front ....5000wt
Middle ...5000wt
Rear ......3000wt
#254
