Tekin RX8 1/8 Scale Brushless ESC Thread
if it works ok some of the time, i would check your sensor wire. i have seen several of them break 1 of those stiff, tiny little wires. that is the only issue i have with tekin. wish the would supply a more supple sensor wire.
So I now have a second RX8, a brand new replacement for my previous failure which is still awaiting rma.
....same exact problem. I ran Thursday, packed up and went home. I just plugged in a battery at the track, turn it on, no tones and no response to throttle.
2nd race weekend in a row ruined.
I'm surprised at how many problems people have with the RX8. I ran my first RX8 with a 1900 motor for one full year before I got one of the newer models. Nothing was wrong, but I decided to run the new model and keep my older one as a spare. So far after 2 years, I have yet to have a problem with the ESC. I did receive a bad motor, but after playing with it for a few minutes we had everything figured out and working properly.
Cars is at the track tonight, but in the morning, I will closely inspect the sensor connector on the motor and then pull the back off and check it out.
new rx8... where did I go wrong?
turn on esc, hold the mode button for 3 seconds, lights in the middle... not touching radio...ding-a-ling-ding-a-ling, beep beep beep beep ding-a-ling light goes to far right, hold trigger... nothing..
reversed throttle on radio repeated previous steps same result...
after a few times of this i hit the brakes while the esc was searching for throttle (the radio was still reversed) and it went ding-a-ling... pulled back the throttle while esc was searching for brakes and nothing again... so maybe the radio doesnt need to be reversed?
i gave up for a while and began searching on the internet... and read a few things about the "neutral zone" ... then began round 2
radio normal...without calibrating... i started adjusting my throttle trim until the esc lights went out.. hit the throttle car goes forward but seems slow, this is my first e-buggy so i am thinking maybe they just looked faster on the track, then i accidentally hit reverse and the car took off backwards with the acceleration i was expecting...
i am guessing if i reverse the motor and then reverse the radio and it would be all good... but I wanted input on to what i am doing wrong before I played with this anymore...
wires are all connected correctly, brand new equipment in a brand new mbx6 eco...rx8, 1900kv tekin motor, mx-3x radio...
any help would be appreciated.. thanks in advance
Another race day and still more issues. I ran 3x6 minute qualifiers, the XT8 was awesome, TQ for the final against the gas cars. Took off from the front and slowly pulled away, no issues until the 7 minute mark, hit the gas and nothing!! Pulled the trigger again only lightly and had power. I tried giving it full throttle like I was before and it would have no power, none at all, until I let off abit. Did a battery change and this continues for the rest of the race. Very frustrating, but still won the race by a few laps. I thought the motor was temping, but the motor was about 65c after the race, which is similar to the qualifiers, which hit 70c. RX8 temp is fine too, so not a temp issue on either and with a battery swap in the middle of the race, its not a battery issue. Geared 48 spur, 15T pinion with a 2000kv. Any ideas?
So has everyone that owns a RX8 had problems? I trying to compare between the RX8 and Castle. After reading all of the problems on the this post , it looks like the castle works better but is not as smooth.
Tekin if you guys could tell me how to get it to run every time then I would buy one since I already the rs versions in my 1/10th scale.
Planning on running 1/8th scale oval with a 3s.
Thanks in advance
B
Thanks in advance
B
To be honest, with as much as I was told that these latest version RX8's are to be as best as best can get, I'm still skeptical after only getting three races out of one of them. We'll see. I've tried driving toned down MMM's and they are still agony to drive so I guess that I'll just keep Tekin's number on speed dial for now.
so i took it out again today and its actually not faster in reverse its slow either way... it just seemed faster in reverse in the short runs last night... i am guessing by by trimming my throttle i am limiting the amount of throttle input only allowing me to go to about quarter throttle... i definitely need to get this calibrated, is there a trick or am I missing something?
You have to get that calibration done. Your problem sounds like a neutral width problem. Try increasing the neutral width on the esc if you have a hotwire. I think you can also do it with the mode and increment buttons on the speedo directly also.
all epa's are at 100%, all trims at zero... i tried adjusting the neutral width all the way up, and all the way down and that didn't make a difference.
During calibration will find neutral the light will go to the right and i can hold the throttle for minutes and it will wont find it, with the throttle reversed in the radio I get the same response... it will find neutral but wont find full throttle...??
R/C Tech Elite Member
I don't think the Airtronics radio needs to be reversed on the throttle channel...
That should help eliminate one variable.
I also had an RS Pro once that WOULD NOT calibrate correctly to a DX2 radio... It ended up being a problem with the radio in the end, because even with another DX2 it ended up calibrating just fine.
Try borrowing a radio from somebody to make sure it'll calibrate to that just to eliminate that variable.
If you never succesfully complete a radio calibration the system will be erratic at best.
IF the system won't find throttle or brake flip the "rev" on the channel.
If you still have an issue try using your ch1 and see if it calibrates, if it does you may have a bad receiver or even transmitter.
Any odd power issues need to be looked at. First thing is to make sure you're rotor is good. Take it out and make sure that the magnet body is not seperating from the shaft. Since you finished your race though this is not likely the issue.
Anytime you've got erratic throttle or glitching the first thing we do is pull the sensor harness from the esc. If you have a bad sensor harness or bad motor sensor board it can cause these types of issues.
wow I was thinking about getting a RX8 but it sounds like it has more issues than it is worth and the warranty ain't that great compared to others and having to tear apart a motor after three races? Steve Neu makes better motors IMO
