Tekin RX8 1/8 Scale Brushless ESC Thread
#5462
I take it the new red heat sink version is a running change and no modification to the part number? Any known resellers that have the new version? I don't want to buy the older one and am tired of waiting for the LRP stuff. I'd like to get the updated RX8/1900kv combo but will buy separate if the combos aren't updated yet.
Thanks!
Thanks!
#5464
The Tekin system has the same problems over and over... bad rotor... bad board... bad rotor... bad board. It's really getting expensive, time consuming and EXTREMELY frustrating.
I will say that Tekin's service is incredible. Ty has helped my time and time again without any hassles. I just wish the product was better.
#5465
The RC Pro International Finals were this weekend and three of the top five were running Tekin. There were more in the triple A mains but I don't know the others. The 3 in the top five were running the black heatsink version. I have a red heatsink as a spare which is now going into a test buggy.
The track was extremely brutal and a very long straight. I learned so much it is unbelievable. Billy's Xcelrion system had good torque but I would have to lift 3/4 the way down the straight in order not to run over him. Brent's LRP had the top end but didn't have the rip to clear the tough jumps without having to pre-setup for them.
1 David Joor (Tekin w/Avid Ceramic Test Bearings)
2 Billy Fischer
3 Brent Thielke
4 Chris Allison (Tekin)
5 Ron Atomic (Tekin)
2 Billy Fischer
3 Brent Thielke
#5466
Team Tekin
2 Billy Fischer
3 Brent Thielke
2 Billy Fischer
3 Brent Thielke
Awesome job David! You were the most consistent driver all weekend for sure!
#5468
Congratulations David! That's a line up of "who's who" in R/C from past and present!
Losi 2.0 with 1900 is 45/16
#5469
well randy, my red heatsink RX8 went bad on me again. It's getting so bad, it makes me look like Im doing something wrong. I connect A to A, B to B, C to C, +/- for the battery, program it, and drive the hell out of it. Then it did the stop and go on me. This time, i did have steering, but no power to the motor. So, is it the motor or the ESC? I would think the ESC. If it's the motor, wouldn't it just will not work.
I went to try to take a look to see if i can 100% confirm if it's the ESC or not. After looking at everything, i notice that one of the plugs of the sensor that's attached to the motor was broken off. Can this possible create this on/off of the motor behavior as I was describing. I am not thinking it will. With one wire not connected, I would think the system will act as if there is no sensored wire. Please confirm...
#5470
Yes it could. If you get a bad or inconsistent connection on the sensor plug it can creat a few different conditions. Fastest thing to do, pull the plug out of the speedo and run the car. If it works the whole time you've found it.
#5473
You're going to need to run the car for a bit to make sure that's what it was. I've had a sensor harness short on me and it caused me to quite a bit of agrivation trust me. Pull the sensor harness out of the speedo completely. Run the car this way as it will prove the sytem works. The sensors and circuitry is pretty sensitive believe it or now. Causing an intermitent connection there is most likely causing some super erratic operation.
Run it around and jump a few curbs with it out front, I do ! LOL
#5474
before I throw my $$ into 1:8 off road...
An EP(yes, got to be "Electric"... ) guy's beginner question: What battery is most common here, so that its speed will be compatible with the Nitro siblings.
14.4V on 4S? or 22.2V on 6S??
By using 5000mAH batetries, whats the run time I get?! 20minutes? 30?
If I'd posted my question on a wrong thread, feel free to remove this, or kindly redirect me to the correct thread.
Cheers!!
Cheers!!
