Tekin RX8 1/8 Scale Brushless ESC Thread
#1846
#1847
I think the current limiter has the same effect as the EPA on your transmitter. Because the ESC chages the frequency of fet on/off to control the power delivery to the motor. EPA use the same theory. For my opinion,if you and your battery can handle the current, you just leave the current limiter off.
#1848
Actually its not the same thing. The EPA on your transmitter will not only limit the acceleration, it will limit top speed as well. Current limiter or punch control basically just limits how quickly the motor can spool up. it will still reach the same maximum speed, but the more current limiter or punch control you set on the esc, the longer it takes to spool up to that maximum speed.
#1849
#1853
I do not think the ESC can know the actual current. The mcu on in the esc just control the frequency and on/off ratio of FET according to the pwm signal from the receiver. And current limiter on the esc is to limit the frequency and on/off ratio. EPA on the tranmitter is also to set the on/off ratio of pwm signal. So I think for proper setting, they should have the same effect.
My point is that its more of a spool up timer than an actual current limiter, but limiting the rate the motor can spool up will certainly limit the amount current it can pull.
The EPA is not the same thing. If you set the EPA to 80% you get 80% acceleration and 80% top speed because your radio will not let you give more than 80% throttle. The current limiter setting or punch control simply limits the rate at which the motor can change RPM, but it doesn't limit the top rpm because it will still see full throttle. It just will take a little longer to get there.
Sounds like a reasonable assumption.
#1854
#1855
Getting to your question (finally ) , no 20 punch control more than likely does not equal 20 on the current limiter. You will have to mess with several settings to find out what is comparable to your old MMM settings. Just be wary that when you take a jump and there is no load on the car the throttle response will be more crisp (the way it should be) compared to punch control.
#1856
Hay,
What do you think about me putting RX8 1400kv. system with 6s in a slash !
HE HE HE !
HE HE HE !
#1857
#1858
Thanks for the answers Jeff and Krio, but it sounds like you have conflicting ideas. I realize I will have to play with the settings as they won't be the same as my previous controller. The reason I ask about current limit and the meaning of the numbers, is because when Randy posted a screen shot of a typical 6S hotwire setting he had the current limit at 85. The screen shot is below. Once I better understand the value I can know where to start setting it at and make adjustments in the right direction.
#1859
Althought they are relatively inexpensive [$12-$18] , I have had very good luck in very harsh conditions. With the one currently running on my Slash having lasted over 1 year, it is a good investment.
My new Tekins, are running under 100 degrees.
#1860
