Tekin RX8 1/8 Scale Brushless ESC Thread >
Like Tree3Likes
Old 08-14-2013, 09:45 PM
  #18151
Originally Posted by Randy_Pike
What Battery? Servo? Radio system? and what do you mean by glitching exactly?
Ko propo fm savox sc1256 zippy 6000 50c
It sounds like the gears are grinding but it's not like its runing on 2 of the 3 phase
9turn is offline
Old 08-15-2013, 12:02 PM
  #18152
Daebech2475's Avatar
Trader Rating: 58 (100%+)
I am running a brand new Futaba hv s9352 w thunder power 4s; Spektrum sr3500 micro rx. Getting a lot of steering glitching. I guess I will try another servo, I have a bls351 that Iv'e never had issues with. Just got a couple seasons on it. Surprised I'm getting this glitching from a hv servo, I thought they were supposed to handle the high amounts of power that comes with elec. 8th scale.
Daebech2475 is offline
Old 08-15-2013, 01:50 PM
  #18153
Team Tekin
yzracer758's Avatar
Trader Rating: 18 (100%+)
Originally Posted by fq06
Besides what Jeremy suggested, for the lipo pack I'd look into SMC that makes a 3s in a 2s case. There may be others doing that, not sure but I know SMC makes one that's about the same weight as a 6500 2s.
@Jeremy
Is the T8i about the same weight as the HD? If so... T8i is the motor. If the HD is lighter, is it enough to be a benefit considering power to weight?
T8i: 274g
Pro 4 HD: 221g
Even with the weight savings from the Pro 4 HD, the T8i has a longer rotor and stack providing more power where the 1/8 buggy will benefit more with.
yzracer758 is offline
Old 08-15-2013, 01:53 PM
  #18154
Team Tekin
Randy_Pike's Avatar
Sounds it's cogging. Does it only do this in low speed corners for example?
On your battery are you using bullets(solid or basket style) or deans?
Randy_Pike is offline
Old 08-15-2013, 01:54 PM
  #18155
Team Tekin
Randy_Pike's Avatar
Are you using the Rx8 Gen1 or Gen 2?
The HV servo is rated for 7.4v so if you're using a Gen1 esc you're over loading the BEC.
If it's Gen2, make sure you use a Hotwire and turn on the HV bec in the "setup" tab.
Old 08-15-2013, 02:48 PM
  #18156
bummer. It is a gen 1 rx8. I will put in a castle bec I used to use. This should work, & eliminate the glitching? Or should I just use a regular servo? Thanks for the help Randy.
Old 08-15-2013, 03:23 PM
  #18157
fq06's Avatar
Originally Posted by yzracer758
T8i: 274g
Pro 4 HD: 221g
50g isn't a ton.. but it is 50g. For the really small track he's talking about, the HD may be the ticket. I ran the HW 4 pole in my 6.8# Mugen SCT (rtr no body) and I hear the HD has a little more grunt. That 1/10 motor hauls butt even with the weight.
But then if you go to any other track you'd wish you got the T8i, maybe the HD would be too much of a specialty build and not worth the $$$ to find out.
Just a thought since I run 1/10 motor in basically a 1/8 on 2s.
fq06 is offline
Old 08-15-2013, 03:48 PM
  #18158
I had an RX8 that would always get full of dirt. I usually tear it apart to clean it but is there an easy way to prevent or reduce the dirt entering it?
TechX is offline
Old 08-15-2013, 03:52 PM
  #18159
Team Tekin
Randy_Pike's Avatar
Both would work. Do you run 2 2s packs or a single 4s pack? OR 2s SCT?
Old 08-15-2013, 03:54 PM
  #18160
Team Tekin
Randy_Pike's Avatar
You can use clear silicon to plug any holes,etc. If it's fine dust you'll never keep it all out. Best thing is to open it up from time to time, blow it out with compressed air. Take it apart over a towel so you don't lose the buttons
Old 08-15-2013, 04:07 PM
  #18161
I use 1 single 4s pack. Thanks
Works fine now, with the external bec. Nice n smooth.
Thanks.
Old 08-16-2013, 10:57 AM
  #18162
I use 4mm cage with grease on them so they don't get hot slow speed no problem it 10 mph + motor at 160-170 esc same no fans
9turn is offline
Old 08-16-2013, 12:58 PM
  #18163
Team Tekin
Randy_Pike's Avatar
I've seen caged 4mm plugs cause many of an intermittent problem under loads,etc. Do yourself a favor and swap them out if you have any issues.
Old 08-16-2013, 01:23 PM
  #18164
Agreed use 5.5 mm bullet plugs i use those on my race boats and now my rc cars due to they both use the same 5000 mah lipos
mavdriver is offline
Old 08-16-2013, 09:12 PM
  #18165
Hi All,
I did a search and this seemed like the best place to put this.
My Tekin T8 2050Kv motor seized up on me last Sunday. I was coming down the straight 2 laps into my main and all 4 wheels locked up. I had steering but no throttle.
I got back to the pits to find it would not roll.
Now the motor is over 3 calender years old, but I only put about 3 - 3 1/2 hours a year total ( yes, you read that right....3+ hrs a year.) on my equipment.
I only get out on race days and run my three 5min quals and my 10 min main.
I race about 6 races a year.
It has never been over heated and well taken care of. I'm just about to open it up and take a look.
Any guesses???
Jamie James is offline
