Tekin RX8 1/8 Scale Brushless ESC Thread
Not sure on gearing but you can run some timing with that motor, just keep the motor temp at or below 160°.
Most of the setup sheets are about what you want to run.
Set push to whatever floats tour boat.
Current limit from 70 to 100 depending on how much traction you have at your track.
In hotwire you can right click (or hover or something) on the slider to find out what the different adjustments do.
Need more info for anyone to help you with setup suggestions though.
setup sheets
I just my rx8 gen 2 installed in my 1/8th buggy and was trying to look at some of the team driver set up sheets on the tekin site but I cant seem to get them to open can any of you guys tell me how to get them open or tell me a a different web site where I can find some setups
thanks Brad
thanks Brad
Brad those are actual downloadable entire setup files. The Pdf's have yet to be uploaded.
You can "load profile" those right into your esc, hit "apply settings" and done!
One more thing should I set the voltage cut off for 2 cell if I'm running saddle 2 cells in my buggy ?
IMO the standard lvc's are set too low on all escs.
Hi, I have a few questions about setting up my 1/8 E buggy. I'm a nitro guy and am not used to this. I have a Tekno EB48. Geared 44/17. RX8 Esc and T8 2050 motor. Can I physically adjust the timing on the can? If so, what can I use for reference marks on how much timing it has? I don't see any timing marks. If not, then I just adjust it using the hotwire? I have the timing currently set at 1 on hotwire. I'm thinking about bumping it up to 2
Are you looking for more bottom or top end?
4s right?
Randy, Thanks for the quick answer. I'm looking for a bit more top end. Yes, 4s. I had the current limiter at 92 and went up to 95. I'm not sure if that will give me the extra top end or not.
No not really. If your motor temps were in the 170 or lower range after 10 minutes you can try gearing up a bit. Where are you racing this car?
Rx8 problems
Hi guys - got a problem that I think (?) is with my RX8 (Though I have a suspicion it might be the tekin 1700kv motor)
Basically, I was driving on the weekend, and the car start to cut out.
After a few seconds, or sometime switching it off and on, it would run again - for anywhere between 3 and 30 seconds.
I checked the battery (4s 5000mah 40c) and it still had 4v on all 4 cells (Cut-off was set to 12v(3v each cells) on the RX8)
I took it home, and yesterday tried to get it going with the electronics etc. out of the buggy. This is where I'm at:
I found that pretty much every time you hit full throttle, it would cut out - to begin with, it would show LED's 1 3 and 5.
N.B. This is with no load on the motor, and a cold ESC.
I read the manual for the speedy, and ended up;
1) Checking the solder joints were OK on the 5 posts on the speedy
2) checking the reciever lead was OK
3) Re-Calibrating the radio to the speedy (After resetting trims and EPA's to 0 and Max respectively
At this point, the RX8 will show either LED's 1 3 and 5, or otherwise LED's 5 6 and 7. (About 50/50 as to which of the two sets it shows.)
At this point, sometimes if I leave the trigger alone for a couple of seconds, it will go again (and then only for a split second (sometimes) before cutting out) - other times, I have to turn the ESC off and on - sometimes even that doesn't clear the LED's.
P.S. the latest testing has been done with 4 different LIPO's fully charged and tested for voltage across the 4 cells, and a fresh set of batteries in the transmitter.
I don't have a spare speedy or motor, so I can't readily test them separately to troubleshoot this (And I'd rather not have to spend $300 buying both to figure it out.)
Any input or opinions on this would be hugely appreciated.
Thanks!
Thanks!
Thanks again
ok soooo...wierd I have an ESC question but its been a while!
so I ended up with a gen 1 rx8, ran it and all was good but not sure if anything is set from hotwire or anything so my question is...is there a reset to go back to factory settings without having a hotwire?
Team Tekin
With the unit turned on, press and hold both buttons on the esc for approx. 5 seconds until the Led's begin to cycle. Release when you see the Led's.
Gearing for X3e
Just picked up the Hong Nor/Ofna X3e buggy. Got an rx8 & 2050kv t4. Using a 46t spur. Anyone out there running this buggy w/this setup? If so, any suggestions on where to start w/ pinion? 15 or 16 I was thinkin, but would like to get some feedback if any1 has.
