Losi 1/8 8ight E 4wd Thread
#7231
u have a pm, u might know about it??? what do u run for current limiter?? cause i do u mine at 100 % but the throttle at 80 %.maybe i need to switch them??
#7232
What was originally recommended from me is if you have it at 100% try 50% to start. I can almost guarantee you will be faster (do not tell your buddies). And go from there . . .
I usually run the EPA at 90% but that is just me and is fitting for most of my tracks. Words!
#7233
i wil try it this saturday man,
#7235
#7237
#7239
i got all them but the hybrids the track in the video starts off dry then when the sun goings down wet, moist loamy dirt!!!! the impacts do ok but for me not enuff side bite?? then the loam builds up then forward bite fades, city blocks have everything even in the heavy loam but in the race grove they get kinda wierd? that is why i want to the subcultures.
#7240
They are similar to the City Blocks but have a rounded profile (carcass) and have better handling through the groove. I think the intent of the tire gives you the best of both worlds. Problem is that they wear fairly quick and once the first set of pins are gone . . . They are poop.
#7242
120C but make sure they are at least rated 60C. As far as LiPo cells go there is no true "C" cell rating. There is absolutely no true requirement to obtain a "C' rating at a manufacturer. This is simply a marketing component that some use as a guise for one-up-manship. Gens Ace seem to be popular. I use expensive MaxAmps as they warranty their product. At the end of the day all cells come from 3 suppliers located somewhere near Korea . . .
#7244
Many people around here use the 30c 4s Hobbyking batteries with no problems. Everyone has their current limit turned down anyway, so C rating isn't as crucial.
