Losi 1/8 8ight E 4wd Thread
#4591
just got my e conversion kit.
1) have a quick question, do I HAVE to use part losa4462? which is Motor Bracea and DIFF plates? I am thinking of not using the diff plates. is that OK?
2) how can I increase the clearance (pinion gear to motor plate, pinion gear almost rubs against motor plate)
thank you.
thank you.
No motor brace but you Need the diff riser to allow the spur to spin free without binding...Also plugging the old spur hole is nice.
Do Not use the motor brace it Will cause stripped spurs and un needed flex in the motor.
I shim my diff with a .1 on the mount side and i was even forced to shim the part of the mount you bolt to the motor itself...Needed 2 .1's under the mounting bolts or i couldn't slide it into the main mount.
#4592
the weekend?
Hey casper how was ur Saturday at the outdoor race? Hey June I did find bearings in the rear hubs that I changed out cause they was bad. And I set my gear mesh alittle looser and cut some vents in side of the body and made a roof vent for more cooling. And the.temps was 150 on the motor and 105 speed control. The main temps was 165 motor and 100 on speed control. The gearing was 13-45.
#4593
My race on Sunday went great. I qualified 2nd and finished 2nd. Outside temps were not nearly as hot as I was expecting. Only around 85. Motor temps were only around 110 with the heat sink. My buddy who ran without the heat sink only had motor temps around 125. 1700/4S setup.
Traction was not as good as could be expected either but it was a fun race on a pretty small track. After 10 min race I only lost by 1.5 sec or so. There was a 3 way battle in the front for most all of the race as the top three Losi cars put a lap or more on the field during the main for a losi sweep of the podium!
165 after a main is ok. Assuming you are ok with the performance I think you are good there!
#4594
What track was it?
#4595
Sold my 8ight
#4597
#4604
you need a 10 tooth pinnion with a metal 45 tooth spur,or go to a 3s lipo. that motor is way to much power for a track. on 3s is better to handle. turn the punch control to 100% and 0 on timming would make it better with 4s. but i never tried that, i went to a 1800 kv from castle.
#4605
[QUOTE=FlyingFINN;7573881]Will the new v2 shock towers fit on 1.0 buggy?[/QUOTe
the 2.0 buggy towers will fit the 1.0 buggy.
