x60 truck
#391
#392
Here is a link to the carpet track we race on here. When we do the big race in March it will be a little over twice the size of the one in the videos. On the smaller track all we run are 1/18th scale cars.
http://www.sweetwaterrc.com/indoorvideos.htm
#393
Hey
Can somene please just let me know what the spring/oil/piston combo is for the losi shock setup on the x60, i cant find it in the manual on the net and i figured i'd get started on that before my truck arrives
thanks
thanks
#394
The set-up is posted in this thread a few pages back, the shocks from the "losi-shock" set-up are:
Front: Losi 1.0's, 56 (red) piston with 30 wt oil, .090" limiting inside, red spring
Rear: Losi 1.2's, 56 (red) piston with 30 wt oil, no limiting, pink spring.
HTH, Paul
HTH, Paul
#395
On your site you say that Amain hobbies is a store that sells your products, They don't even show you in inventory, Is there a reason?
#396
#398
I'm not sure where you see that Amain hobbies is an X Factory dealer? If you look on our contact pages, "Hometown Hobbies / A main raceway" is a member of the dealer family, which is perhaps who you're thinking of? Hometown Hobbies is a store located in Portland Oregon.
#399
hi paul
i pick up some losi shock for my x-60 i`m going to give them a try i have been have a problem with the truck nosing down on alot of the jumps offroad indoor carpet i`m sure it coming from being to soft in the rear
t4 rear shock 2 piston 30# black springs 3 limiter
#400
crazyjr - no problems.
gone banana - what's your full set-up? Those rear shocks don't seem too far off. I would probably suggest looking at your ride heights first - reset it to front arms level and then set the rear so the chassis is level. Another thing - are you running the rear wing? That wing can actually make a difference; mount it with some large washers and slot out the rear body mounts like I mentioned above.
#401
Just wanted to post up some pics of my X-60, first run this weekend at the rocky mtn indoor champs.
I am running the factory setup
Fantom 13.5 motor
LRP Sphere TC
spektrum radio and reciver
Orion 3200 2c lipo
Futaba 3305 servo
and a BIG Thanks to Khador12 for the awsome paint
Fantom 13.5 motor
LRP Sphere TC
Orion 3200 2c lipo
Futaba 3305 servo
#402
hi paul
#403
I am excited to race my X-60 this weekend. I had a chance to test it on a 1/18th carpet track this pat weekend and could not believe how easy it was to get aroud the 40 inch lanes and tight track. This week end the track will be a 1/10th setup.
Good luck to all the drivers racing at the Cactus Classic this weekend!
#405
Suspended
