x60 truck
#376
Ok, my next race will be on carpet. I am debating on ordering foams or not because this will be the only race on carpet all year. It is ozite and jack the gripper is the only traction compound allowed. What do the rest of you think?
#377
Can you borrow some from anybody at the track? Or perhaps "rent" some for like $5? If its only going to be one race, I would hate to have to lay out the money for two pairs of tires you probably won't need again.
#378
This will be a first for most everyone at the race. So I may just try panthers or barcodes.
#379
Not looking to race the Cactus. I am comming back after a looong break. I haven't built a car since the days of my RC10 goldpan and don't have a donor vehicle. I figured if I could find someone with an already built an X-60, I could reimburse the purchase price and throw in an open boxed, unbuilt TC4 for their trouble (way too complex for me ).
#380
Hey Mytimac, There should have been two sizes of threaded inserts in that little bag -- four 1/2" long and 2 shorter ones, 3/8". The two short ones go under the bulkhead, and if they are installed correctly in their hexes they should not protrude behind either the chassis or the bulkhead. For that to happen both chassis and bulkhead would have to be badly mal-formed, and your car probably would not run.
The four long inserts hold the transmission in.
If there has been a mistake, it's hard to get the inserts out of the chassis. Far easier to just get a new set of #6300 threaded inserts, put the short ones in where they go, and have some spares.
#381
Chris
#384
If you really don't want to run foams, then a low pin/slick rubber with a STIFF foam would be closer than a regular tire. Maybe a taper pin.
#385
I used the kit set up with AE shocks the only change I made was AE gray springs in the rear and AE blue springs up front. If you need any help let me know I will do what I can to help.
#387
gilley tv on youtube
http://www.rctech.net/forum/wisconsi...ois-racing-11/
http://www.youtube.com/profile?user=...tv&view=videos
the plex glass is to act like ice if you pull the trigger it loop u around
#388
I have a question for the X Factory guys. Are the 4-40 x 1 1/2" flat head screws used to hold the battery down going to be available? The head on mine stripped on install, and that is a hard size to find. Thanks
#389
here is a video that I found from out local track as well
http://www.youtube.com/watch?v=TtOYoKl-7ls
Mike Ciresi
Mike Ciresi
#390
Mike Ciresi
