Gear ratios for Losi XXX-4 >
Old 05-04-2008, 07:14 AM
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
Default Gear ratios for Losi XXX-4
Just picked a xxx-4 and i wanted to know whats a good starting gear ratio for a 10.5 and a 13.5 motor?? thanks
Marcos.J is offline
Old 05-04-2008, 07:22 AM
frankiecmgt's Avatar
Trader Rating: 77 (100%+)
I was running a 19/92 in mine with the 10.5. That was for the indoor track i race at..kinda tight but flowing. I had plenty of speed coming off the corner's and top end was really good. This was also with a 7.4 li-po, running a regular 6 cell you might want to drop down a tooth on the pinion. Hope this helps you out some.....frankie
frankiecmgt is offline
Old 05-04-2008, 07:25 AM
This is my home track....rcexcitement.com
Attached Thumbnails Gear ratios for Losi XXX-4-indoor_off_road_track_1_small.jpg
Old 05-04-2008, 11:02 AM
I am currently doing testing for Banzai Motors on their new brushless motors and speed controls. I started with a 25/92 with the 10.5 and i have gone to a 26/92. I was told to go as high as possible but still keep the temp below 160. every 5 min i temp the motor and speed control to make sure the temp doesnt get any higher.
With 26/92 the motor came off at 156 and the speedo was at 140.
Hope that helps
Daniel Sarfati is offline
Old 05-04-2008, 06:50 PM
Super Moderator
Marcos.J's Avatar
what about a 13.5??
Marcos.J is offline
