Lipo charger for Orion BAtt.
I am new(again) to RC and plan to race my xxxt-cr this summer. I ordered a few Orion 3600 lipos. WHich charger would be good to get and not too complicated? Is there any advantage to getting one that is only DC? I have search a bit but not found what I am looking for. I see that the Hyperion is highly recommended but not sure if it works easily with the Orion BAtt.s What about the Core RC charger? One with a built in balancer would be appreciated.
If you go with one that has the AC/DC built in, if you decide to run multiple chargers later, you'll have to buy another one. If you get less expensive and smaller DC-only (Like the orion avionics) and a power supply capable of running multiple chargers, it would make that much easier.
Other than that, no advantage that I know of.
I just recently went through this same process of deciding what to buy and at the end of the day, any of the major brands will make you happy.
I have an Orion 4800 pack and originally bought the Losi (blue/eflite clone) Lipo Charger/Balancer combo. That Losi charger did fine on 1350 mah 3s 11.1v for my rc18b but when I tried to charge at 4.8 amps the Orion pack, the Losi showed a little stream of smoke and died.
Horizon's had that charger for over a month now and still hasn't replaced it.
In the interim I bought a Triton Jr.
http://www.electrifly.com/chargers/gpmm3152.html
and while it doesn't do balancing, I love it's charging features and it's been awesome especially for the price.
This seperate balancer -- http://www.electrifly.com/chargers/gpmm3160.html
works well, is cheap and has a good supply of useful connections.
Be sure to check out Team Orion's site for instructions on adapting a wire rig for balancing with the equinox (and avionics) balancer.
I strongly recommend you stay away from the Losi Charger/balancer, though. My local hobby shop has been pushing those and I don't think it's worth the money. Some people have had plenty of luck with them but my experience was bad. The ICE is real nice, too
I have three Ice chargers. I use them for two Orion 4800s and one Orion 3200 After a full season no battery is out of balance by more than .01 volt.
Interesting that you bought some Lipos. You only need one per car. I have never pulled enough current out of one to not be able to be charged for the next heat race. I have run in carpet oval as well as dirt off road. It is also possible that you are running several vehicles.
I bought two so I wouldn't have to worry about charging as much. And I could have them charged when I show up to drive and have plenty of driving time before I worry about charging again. Probably overkill. thanks for the input.
I have 2 of the orion 4800 batts and charge with a 10w dc ps and the orion avionics lipo charger. I have an orion advantage for my nimh also. Im glad i didnt first go with a charger with the integrated PS since i can run 2 chargers if I'm drawing less than 10 amps.
after a few months of charging with no balancer my cells are still perfectly OK. we checked on a trakpower balancer.
I'm considering getting 2 3600's to use for racing and using the 4800's for my basher car..... even though the new orion 3 cell graphite edition looks pretty sick.
I would highly recommend the Hyperion EOS5i with the built in ac/dc. This so far has been very reliable. Just taking it out of the box and feeling the charger in your hands, you can tell that it is a true quality piece of work. So yeah to anyone out there looking for a charger and can't decide because there are too many to choose from, the Hyperion line of chargers is the way to go in my opinion.
Are the Hyperion Chargers "plug and play" with the Orion Batteries as to the balancing plug or do I have to rig one up?
You got to rig one up unfortunately.
