Like Tree495Likes
JConcepts Thread
Old 06-28-2023 | 02:31 PM
  #10471
How many 5-minute runs do Silver Smoothie 2's usually last before replacement when running on high-grip indoor clay with kit foams?
Currently using SXT Baja Max, any other recommendations for a near odorless sauce? (Don't want to use liquid wrench if possible)
MrLean is offline
Old 07-31-2023 | 12:17 PM
  #10472
Cain's Avatar
Tech Legend
So after talking a bit with a Jconcepts Team driver local to my track about what we both think would work for tires on our turf surface that is rubber backed, he ended up ordering some drop steps. Those basically are the hot tire now on our surface. The perform similar to what I was hoping, the smaller pin portion biting into the surface while the larger step portion provided some stability. The tires appear to "release" more consistent in a turn that we were seeing with pyramids or mezzos.
He also did run with an idea we used in the old days prior to him running Jcon stuff, going with a 4wd front tire on a 2wd standard rim, similar to what was being done by the racers in Japan using schumacher fusion tires. Pin swags were his hot tire and definitely looked more consistent out there than the skinny version.
With the release of the standard pin swag and fuzzbite fronts, what conditions are envisioned where you go with these tires versus the skinny versions? How much of a weight difference with including that new foam insert over a skinny?
Any plans for some premounts?
Cain is offline
Old 08-06-2023 | 10:26 AM
  #10473
Received a couple sets of 2WD Fuzz Bite (WIDE) Front tires this morning. But not enough time to glue them up for the track. Plus one pack had mismatched pair with one Pin Swag and one Fuzz Bite.
shortcut3d is offline
Old 08-07-2023 | 05:16 AM
  #10474
PW's Avatar
PW
Please contact us directly and we will get you a new set sent out ASAP, sorry for the mispackaged tire. I will pm you a direct email
Cain and savage24x like this.
PW is offline
Old 08-07-2023 | 02:58 PM
  #10475
Thank you for the great customer service.
Old 08-09-2023 | 11:54 AM
  #10476
Yeah I had an issue with the JC team only sent me one set of tires when I had ordered two. Great to see the team looking out for their customers.
Their returns could use some work though
CosmoM3 is offline
Old 08-10-2023 | 11:20 AM
  #10477
Cain's Avatar
Tech Legend
following up in cased it was missed:
Cain is offline
Old 08-10-2023 | 12:31 PM
  #10478
The new tires weight 5-6g more per wheel/tire than the narrow.
I'm not sure about use situation but they definitely have more steering.
mbrienzo is offline
Old 08-17-2023 | 05:27 AM
  #10479
PW's Avatar
PW
They are intended to give smoother initial steering, but overall more steering throughout the entire corner.
Cain likes this.
PW is offline
Old 08-17-2023 | 09:21 AM
  #10480
jabroni racing's Avatar
Hey Paul, Its Jay, been a long time, LOL, , just got back into racing after a good 6yrs out, I notices 1/10 truck tires out of stock, also backorder on online sites i use, any idea when they will be back in stock, looked at sprinters and goosebumps, Thanks for any info you can give..
jabroni racing is offline
Old 08-17-2023 | 10:10 AM
  #10481
PW's Avatar
PW
Hi Jay and welcome back!
We do have green Sprinters in stock, but currently out of blue and green Goosebumps. Once you click on the Sprinters, you have to change the compound to green in the compound selection drop-down box, then you can click to buy.
jabroni racing likes this.
PW is offline
Old 08-17-2023 | 11:36 AM
  #10482
Cain's Avatar
Tech Legend
thanks for the info. So far so good with the wide 2wd pinswag fronts. Felt pretty consistent around the track and seem to have a bit less fold over than what I was seeing with some skinny fronts, maybe due to the foam? width looks the same as the 4wd variant.
Curious if anyone has tried the these for a 4wd vehicle front? Only thing is they are not as tall as a rear tire though, so not sure how much of a diff it will matter, I know schumacher made the fusion 2s to be taller in height to get more even with there rears. But I do like how these don't fold over.
Cain is offline
Old 08-17-2023 | 04:12 PM
  #10483
Does this mean gluing the sidewalls is no longer necessary?
Old 08-17-2023 | 04:32 PM
  #10484
Comparison
4WD Fuzz Bite Front: 27.3mm W x 8.5mm H (sidewall)
2WD Fuzz Bite (Wide) Front: 26.2mm W x 5.5mm H (sidewall)
I was able to glue the 2WD Fuzz Bite (Wide) Front using the Raceform Lazer 1/10 Jig w/ Carpet Conversion kit with the recommended 2WD front plates (2R+2R+5R+5R) vs 4WD front plates (3R+5R+5R). This seems to align with the slightly narrower width. You do have to 'help' the tire to start pulling back the bead, but otherwise no issue (stayed correctly peeled back and reseated the bead nicely the entire circumference).
JConcepts Fuzz Bite 2WD (Wide) comparison
Cain likes this.
Old 08-17-2023 | 04:47 PM
  #10485
thedak's Avatar
thedak is offline
