JConcepts Thread
You just cut the 4wd front insert straight down the middle (half width) and put into the front tire. It seems that the front tire having a little more give seems to take away a little of the twitchiness. The narrow insert just supports the center of the tire a little and doesn't really seem to shift. Glued front sidewalls almost always on 4wd fronts.
Tech Legend
thats really cool!
heck, makes me wonder if its possible to make some adjustable cutting guys for foams inserts. can just dial in the width you want and go. I'd buy some
I did some brainstorming on that, but couldn't think of a way to make it easy to print without warping, and durable enough detents/locking mechanism to be reliable & consistent. Front and rear foams having differing ID & OD make it more challenging as well. I'll keep pondering it - in the meantime I'm making various sizes available.
A reverse cut would make for a smaller guide, but unfortunately, some of the inserts out there don't come in a uniform width, so we'd need multiple spacers and measurement steps for a pair of foams.
I'll post up some pics of the next iteration tonight. Thanks for the ideas and support - sorry to keep spamming your thread PW!
Cromulent - how are you cutting the insert once you drop it into your jig? Are you just using flat blade to run across the top of the jig?
Nice work.
Nice work.
Nice.
Made a thin walled version for the front foams that can nest inside the rear foam cutting guide - less space wasted in the pit box! The thin walls seem to work just fine on their own as a cutting guide and should be plenty durable. I'm stoked Spacers would be easy to fabricobble if one wanted to experiment.
Tech Legend
Anyone got some pics of how high they are gluing the sidewalls of the fuzz bite 4wd fronts?
PW is there a way to fix these inserts?
The one seems like they forgot to cut the flutes out.
I don't know if it is a result of the supply chain issues that everyone has been dealing with lately, or what, but I have experienced that foam defect with every major tire brand. Most often with PL, and a few from JC, and AKA. Its been a regular enough occurrence that I have been able to match sets of foams with the short inner tabs.
