JConcepts Thread
#9481
#9482
However, those come prepacked and will most likely be all the same.
#9483
You can send an email and let them know - Click Here
#9485
Can anyone tell me if the JC lower front wing mounts for a B6 (2547-3) will fit a B5M (yes, I know there are B5M specific part number 2547-1)
Only reason I ask is that I noticed Proline's lower front wing kit suits both the B6 and B5M's (see here)
https://www.prolineracing.com/perfor...lum-b5m-b6-b6d
I can get the B6 mount easier for my B5M but want to make sure before I pull the trigger
#9487
Dirt Webs shoes - clay compound! Will be the most hooked up corner marshall ever!
#9488
Not right now, but on the list.
No plans right now.
We have never tried; I will check today and let you know ASAP.
Any plans for 1/8th scale buggy Octagon tires?
#9491
The bolt pattern is basically the same, but the mounting is different. You can make the B6 one work, but it's not as secure. The B6 carbon tower is countersunk for the screw and the mount has the countersunk portion molded into it for secure mounting. The B5 "molded" tower has a straight bore for a button head screw. So when using the B6 mount on the B5 tower, you won't be able to tighten the screws as tight.
Both B5 and B6 mounts are in stock.
B6 Tower
B5 Tower
B6 Tower
B5 Tower
#9492
The 22T 2.0 Finnisher body was a direct fit, but I believe it has been discontinued as it is no longer on the website. However, I am not sure any of the T5 bodies can be made to fit. Your best bet would most likely be the TLR body.
#9493
We are actually going to re release the the 22T 2.0 body part #0291
#9494
#9495
Team Driver JR Mitch:
