JConcepts Thread
#901
i cant justify spending the 10 bucks for assoc sheet unless thats what you are talking about
#902
I'd think the tray would outlast the chassis film by a significant margin and it protects the edges of the plate better, not to mention just being neater overall...B44 tray's going on mine as soon as it's available.
#903
From: Castle Mamba Max Pro. Feel its power!!!!!!!!!!
What is the differance between the Rounder and Groovy front tires. From the pics they look the same but I know something is different. Sorry if this has been asked before.
Brian
Brian
#905
Baumgartner is pretty much onto it. There are some revisions that arent quite obvious, but the tires operate in a similar manner to what he suggested.
#911
Yes we do. There are many others available at rc10b4.com also.
http://www.jconcepts.net/index.php?/...in_detail/kits
#912
The BJ4 Setups are pretty standard though. From the Highest bite blue groove or clay, to running on super loamy tracks, there are only a handful of changes I really make.
Bite: LOW ---> HIGH
Fr Springs: Green ----> Silver
Fr Oil: 30 --> 35 ---> 40
Fr Shock Upper Mount: 2 ---> 1
Rear Sway Bar: Off ---> On
Rear Oil: 25 ---> 30 ----> 35 (extreme bite/heat only)
Rear Spring: Green ----> Silver
Rear Wing: 7" HD Full Lip ----> 7" no Lip ---> 6" HD partial lip ----> 6" HD no lip
That about 98% of the setup changes I will make....super low bite, startes with all the stuff on the left, and super high bite is the stuff on the right. We have the JBRL series here in CA, and I can usually watch a couple of guys run in practice, and guestimate the approximate setup using the model above, and it is usually really close.
Hope this helps!
Bite: LOW ---> HIGH
Hope this helps!
#913
#914
We started a JConcepts Clash thread here:
http://www.rctech.net/forum/showthre...82#post3774582
In case you have any questions or comments. Thanks!
495Likes
