Like Tree495Likes
JConcepts Thread
Old 08-05-2008 | 08:43 AM
  #2041
proguy - I tryied 2 stage foam for more forward bit and actually got more overall traction. I run on hard packed sand/clay tracks.
David Alberico is offline
Old 08-05-2008 | 03:46 PM
  #2042
I started running at ocrc. It is the dirt from so cal raceway. Most people run holeshots with bomb one. I have tried x3000 in pink with bomb one they were a close second to holeshots. At the end of the straight the double dees just would wash out to much. I thought that might be from the soft foam. The soil is pure dirt and when wet is hooked up but as it drys out there is a small layer of dust that causes the trck to become loose. Thought the double dees might help.
proguy747 is offline
Old 08-05-2008 | 10:47 PM
  #2043
aeRayls's Avatar
Can anyone tell me what length ae T-buckles I need to use the JC ball cups on the rear of the B4 B44 T4?
aeRayls is offline
Old 08-06-2008 | 06:46 AM
  #2044
Jason Ruona's Avatar
Based on experience with that dirt and surface I would consider trying some buggy grip on the tires. When the track surface has not taken any rubber making the rubber slightly softer normally helps. If you can talk to Frank Root (JConcepts driver) at the track he can probably give you the proper procedure for that track. I would think the stock inserts would work well in those conditions. 2-stage inserts normally work better when the track surface has taken rubber and has a lot of grip.
Jason Ruona is offline
Old 08-06-2008 | 06:48 AM
  #2045
2.00" turnbuckle.
Old 08-06-2008 | 11:29 AM
  #2046
aeRayls's Avatar
Thanks Jason, but I checked the JC website(duh) and it says 1.00" for B4/B44 and 1.775" for T4.
aeRayls is offline
Old 08-06-2008 | 11:57 AM
  #2047
AndyMoore's Avatar
I think there may have been some confusion, our apologies. You are correct, as is the site, but if you use the standard type ball cups on the rear then you'll want to use the stock 2.00" turnbuckle.
AndyMoore is offline
Old 08-06-2008 | 02:07 PM
  #2048
From: anywhere I can race 2wd dirt,and 1/12 onroad in MI.
Default J CONCEPTS HELP!!!
hey guys I have been looking for some green compound goosebumps for 2.2 buggy for like 3 weeks and cant lay my hands on some anywhere!!!Does any body know where i can lay my hands on like 3 pair before august 23?????If any body knows where I can get some please drop me a PM immediately.
2wdMod is offline
Old 08-06-2008 | 02:32 PM
  #2049
rdub202's Avatar
i see you are in MI have you contacted Larry's performance RC's in sterling heights?
rdub202 is offline
Old 08-06-2008 | 02:36 PM
  #2050
Frank Root's Avatar
TLRacing
The Double Dees work good at OCRC. I usually run the stock JConcepts foam, trim the inside and outside edges. Also, try to use Buggy Grip applied about 10 minutes before you run.
Frank Root is offline
Old 08-06-2008 | 03:26 PM
  #2051
COOL!! Frank @ pacific coast hobbies hooked me up!!!! Got the last 2 pair they had!!! - Also man you guys at J concepts , these tires are the ticket in the midwest for out door dirt!!! Need to get more of these in circulation before our outdoor season ends!
2wdMod is offline
Old 08-07-2008 | 06:21 PM
  #2052
AndyMoore's Avatar
Thanks Frank, youre the man.
Haha, thanks! What tracks are you referring to (out of curiousity)?
Old 08-07-2008 | 06:45 PM
  #2053
Andy- If i order something can you bring it with you to the nats?
Chris
Chris Jarosz is offline
Old 08-07-2008 | 08:01 PM
  #2054
$Tmoney$'s Avatar
anyone looking for a bj4
$Tmoney$ is offline
Old 08-07-2008 | 10:08 PM
  #2055
AndyMoore's Avatar
Chris
If you think I can fit it in my stuff, sure.
