Kyosho Ultima RB5 Thread
#1651
thanks guys!!!
The guy at my track running the RB5 has the LRP w/o fan and it fits very well, much smaller than the GTB and running the 13.5ss so it's a baller setup! his car is a torque monster!
The only reason I ask about the different ball studs is that I feel more at home with the Ti ball studs with the hex heads in them, makes life so much easier and they look great! so...picky ol me I guess lol.
#1653
thanks guys!!!
So you will need a left handed 4-40 tap or use the stock rod end and dremel with a cut off wheel two parallel cuts off center 180 deg. apart. Refer to the regular tap for the location and direction of the cuts. And as Casper stated thece cups are top notch!
#1656
got another one.....
can I run the Losi Universals on the RB5? I'm doing the long arm conversion for the rear and have never been a fan of CVD's....do you think it would be possible to run Losi universals?
my thought is you'd have to find the right combo of shaft and axle, then run the losi carrier and bore out the arm hole to fit the pin...but then you'd magically have the uni's....worth it?
#1657
#1659
I am looking at doing the mid. conversion. I found on A-mainhobbies a whole kit for a conversion does this kit have all the items I need for the RB5?
http://www.amainhobbies.com/product_...ducts_id/13250
Tim
Tim
I got my kit and went to install it and realized that it does not include the correct CVD's! you need the stock ZX-5 dogbone, but use the rb5 axle, the mid conversion comes with dogbones the same length as the RB5 has stock, so imo the conversion kit is a waste of $40.
#1661
For the RB5 (Ultima) you only need the arms, hubs, axles and shock shafts so it probably isn't worth it. Then again you will have spare cartridges. And if you have a Lazer you will have spare axles. But yes you still have to buy more stuff to use itt on the Ultima.
#1663
Trader Rating: 23 (100%+)
Just my 2 cents I had a converted zx-5 and a stock one as far as ball studs go. It was a paint to remember which ones were standard which ones that were 4.8mm. The stock one I have ran for 2 years now and haven't broken a ball stud, and the cups are still original. I only run about 3 times a month but the ball studs and cups are the best I have ever used, in a steel plastic combo.
thanks guys!!!
#1665
anybody use a b4 turnbuckles on rb5??
