Team Associated B7 and B7D
#1486
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
I have noticed for sandy astro tracks some of the UK drivers are adding the brass C block, I was wondering if a similar weight balance could be achieved by moving the motor back using a 72t spur gear. I am currently running 22/78, I can get a similar ratio running 20/72 but I think the motor would move back 3/4mm.
If I did the above and also moved the battery back would there be any advantage/disadvantage over the brass c block. Would it achieve a similar ftont/rear balance but with weight more central?
Thanks.
Thanks.
#1488
Thank you, sir.
#1489
Mine arrived today
![Nodding](https://www.rctech.net/forum/classic_images/smilies/nod.gif)
#1491
There is another issue on top shaft.
The inner diameter is not align with the shaft.
See the below Facebook link for the video
https://www.facebook.com/share/v/yXk...ibextid=oFDknk
#1493
It simply means top shaft gear will wobble, causing metal rubbing noise
#1494
Roger. Does the tmg under servo weight need attaching to the chassis somehow or is the servo on top enough?
#1496
Hi folks,
anything heard again of the B7 -4 Chassis?
Cheers Marcel
Cheers Marcel
#1499
Rivkin said on facebook "More rotation and more grip" Which I think basically comes from more weight transfer from the shorter length.
Considering how smooth the car is I can see that being a good change. And that kinda makes sense that both the carpet and dirt kits came with the same chassis.
