Tekno EB410.2 Thread
#377
The horn itself is plastic but has metal inserts (including 23 tooth spline) to match the horn to the servo. Trying to buy them as a Losi packaged part is ridiculous because they always come in a package with a bunch of stuff you don't want, so I get them of eBay. The seller rc-waffle sells these pretty cheap. Here's a listing with the horn, various spline inserts and rod ends for $3.25 plus shipping:
https://www.ebay.com/itm/363690904521
That seller usually has multiples of these listed with slightly varying descriptions and he heavily discounts combined shipping so I would always try to buy a couple at a time. I use them where ever they can be fitted, including on my oval Mudboss cars because they are so strong.
#378
I used Losi 8 buggy/truggy steering servo horns on both my EB410.2 and ET410.2. The truck has a full height servo and the buggy a low profile servo.
Thank you! I'll go look into that now. I roached my only 25t servo, first day out this past weekend and had to settle on a cheap Savox. I'd much rather run a Spektrum 6240 if I can.
#379
#381
#382
I have my EB410.2 assembled - looks awesome! How does this setup look? It’s more than I thought I would be spending, am I overspending? Typical off-road race has 5 minute heats by me. Is a 5.5 turn motor overkill, would a 6 or 6.5 be better? Are these high-end ESC’s required? Are the servos rebuildable? Thanks! My last serious racer was an RC10 GT and a Novarossi .12, this is all a bit new to me!
Tekin RSX Pro
Tekin Gen4 4.5 turn motor
Tekin T-190 servo
Tekin RSX Pro
Tekin T-190 servo
#388
Hello, the low frequency springs will get you where you need to be right height wise. They provide a lot more grip but I only recommend them for clay tracks mostly outdoor. I could not comment on their use for carpet or Astro. I use the green front and the pink rear or the pink front and the pink rear with 30 or 27.5 in the front and 25 or 20 in the rear with the stock Pistons I race on an outdoor clay track with lots of big jumps in the car is very in the track and plush. I did put team Thornhill red bump stops in the rear to keep the chassis from slapping so hard if I don't land the jumps right and they work incredibly well.
#390
215Likes
