Schumacher Cougar Laydown 2019
#211
What are the effects of the front wheelbase adjustments?
I race on a 2m wide carpet track with lots of 180-degree bends and I'm thinking of running the shortest wheelbase possible at the front and shortest (hubs forward) at the rear...although this does hurt on-throttle steering. I have plenty of rear grip, need the buggy to have a better turning radius.
Next port of call is rear sway bar kit
#212
What rear toe are you using?
#213
Flip to the back of the manual and it describes in detail the multitude of adjustments for the whole buggy. But what I suggest to everyone, is to test each one adjustment during a practice timed session. Time go down per lap, continue. If times go up , your adjustments are the wrong way. Thats the best way to see if what you changed works.
#215
Hey Guys,
What's the difference between the U4352 and U7700 gear diffs?
Visually, I can see metal pins vs plastic cross and the out drives are a different color. Are the out drives just a different color or are they a different metal?
Cheers,
Scott
Cheers,
Scott
#220
Hey guys im really thinking of purchasing this car. I'm torn between this and the losi 2wd 5.0. I would race between clay and carpet. I have a tekno 4wd buggy and a losi 2wd sct truck and now im looking to add the 2wd buggy.
#221
Im looking for a clean roller + parts. If anyone has a lead please send them my way. Thanks.
#222
I'm setting up my new to me Cougar for a high bite clay track, should I use the alloy rear hub carriers that came on the car, of switch back to the stock carriers? Thanks, Dave.
#224
Thanks for the help Raul.
