Schumacher Cougar Laydown 2019
#166
I have both but run on carpet. They are both very competitive. The LD has easy access to the diff and is fairly easy to work on and uses standard offset wheels (Associated). It will probably be harder and slower to obtain parts for the LD especially if it is on backorder. I could not find a slipper eliminator anywhere and finally one showed up on eBay. It is still not available from any of the suppliers and it's been that way over a month. Common items are usually not a problem. Get the Klinik battery mount, Schumacher aluminum front yokes, hubs and brass radio plate before the build. Discountrcstore.com is a good source for parts. I think I prefer the LD but like both cars. I also have a Serpent Gen 3 that may end up being awesome. Same parts issues as the LD but worth a look.
#169
Make sure you put the grease on the O rings and thread screw holes before assembly. Tighten evenly. Trish from Schumacher has a diff building video on YouTube that is very helpful. Check it out
#173
Clean chassis with alcohol and 3m tape the fan behind the motor against the transmission. I have 2 cars with fans mounted like this with no problems. I did trim the rear of the body for fit and airflow.
#175
Yes. this is the one i am using taped directly to the chassis. https://www.amainhobbies.com/protek-...k-2112/p996578
#176
Sure, you could go the simple and lightweight route of chassis tape. OR you could go the heavy and complicated route I took: cut down a wallowed out rear A-arm, screw the fan to that, and attach to the two transmission housing tabs above the motor, so the fan blows down onto the can. I'd post pics, but I'm nowhere near the minimum post count.
#177
I'm just running an Associated servo mount above the motor. It only fits a 7.5mm thick fan though, 10mm is a little too tall for the stock body.
#178
I lost my battery orings for the klinik hold down. Any chance someone with the same battery holder would be able to measure an o ring for me? I'm assuming I can find them at Lowe's/home depot.
Thanks!
Thanks!
#179
They are about 1 3/4" across the middle when they are round and uninstalled. I would just take the battery holder and a battery to the store with you and make sure they fit. Good luck.
