Team Associated B6.1 & B6.1D thread
#1478
Just finished putting together my b6.1d and following the kit setup I end up with two degrees of positive camber in the rear. Is there a typo in the manual has anybody else run into this problem?
#1480
#1481
just basing off all the previous kids I did from them it was pretty close this one was off by 4 degrees so I was wondering if I put something together incorrectly if it was off slightly I wouldn't have even cared
#1482
there isn't really anything you could've built incorrect to give a different camber setting. You maybe built something with different settings but that doesn't mean its wrong. If you want to run the book set up then double check your camber link positions and your C/D mount inserts are to the book. Otherwise just adjust as required.
#1483
#1484
Okay my kit will be here next week, I'm building my 6.1 just for carpet. Mostly for this years IOCC race in Vegas 21.5 class, should I use the brass bulk head or the aluminum AE one? front and rear bars or just front? My local carpet track is closed only real testing I can get in will be on Astro.
#1485
Double check that everything is according to the setup sheet in the back of the book. Sometimes the pictures or instructions are different to what the setup sheet specifies.
