Team Associated B6.1 & B6.1D thread
#916
Here is a fan mount pic using the Associated servo mount with a longer screw through the side brace.
#917
They're experienced racers who aren't likely whiskey-throttling on the jump landings with mild power and a proven gearbox design & components and they had 8 idler gears fail in one day. If I were the qc engineer responsible for this product, I'd want those striped gears back to inspect.
Anybody looking forward to putting in a set of cut gears made from these parts?
#918
Isn't the B6.1 suppose to be superior to the B6? Why can't the B6.1 handle a 13.5 with a direct drive with mini pin tires in carpet. The B6 can do it all day long with no gear problems.
Do you even race in carpet?
#921
#922
The B6 did not have that problem. All of us running the B6 before were on slipper eliminators with 13.5 on a super high bite....... no idler gear problems.
#923
Personally I run a slipper on 13.5 or lower. If you want to save some weight, the Avid/Schelle slipper is a nice option to lose some weight (and centralize it) while still having a slipper. It’s what I use on my 13.5t truck and the difference is noticeable.
#924
Thanks!
#926
I am sharing this information so it will help the new owners. Who knows some internet rc engineer in this website might find a way to solve this problem.
BTW.... I installed the stock slipper back and tighten the slipper spring all the way and back out one turn..... we will see what happens.
#927
From what I can see Avid does not yet. But I am wondering if the Durango drive plate would not make an Avid work. Durango drive plate
#930
I'll see if the other guys are having good luck with running a direct drive with the old idler gear color.
