Yokomo YZ-4 SF
#226
what is the difference between these two Ti screw kits?
https://teamyokomo.com/parts/S4-TSS
https://teamyokomo.com/parts/RP-087
Both titanium, one is "standard" Yokomo Ti and the other is RP Ti... but the price difference is miles apart..
5,680 YEN versus 16,000 YEN respectively?
did the RP version come out of a Unicorns ** and polished by the tears of a forgotten angel?
#227
Very durable and to negate dealing with front a arm breaks get the YZ4 +1 front flat or gullwing (personal preference on flat or gull). a arms, as they are insanely durable. Front inner hinge pins will have some exposure, hence not a huge deal and if u would like you can cover with wishbone tube/spacers etc.
https://www.amainhobbies.com/yokomo-...4-017g/p474559
#228
#229
#230
On the bright side, they seem to be made out of a much harder titanium alloy. I use them on my on road cars as they are very true and can help with parts alignment. I have had in the past some problems with some generic titanium screws where the head of a countersunk screw was off and it gave me headaches trying to get my bulkheads right. Not sure I’d use them on off-road, though, and especially not on the bottom as I’d hate to see them wear out because of the chassis hitting the ground!
Martin Paradis
Martin Paradis
#231
I am not sure if the gull wing tower works on the sf ... did you use the stock sf tower with the gull arms ? I guess it would just reduce a couple mm of droop ...
#232
Using the plus 1 front YZ4 a arms do not require different front universals. If you notice your bones are close to popping out of the out drives at full droop, shim the axles thus between the inner hub bearing.
#233
Can anyone post some pics of their centered servo and horn without trims. I can't seem to get mine right and wanted to see how others looked. Not sure of I have a problem with my servo, steering link, or toe links but I can't seem to get to steer properly.
#235
All ball links are in their default location. 17mm servo arm.
#236
I'm curious: I thought you wanted the horn at 90. Wouldn't sub-trimming it to 90 be better than offsetting it, or is that old-school thinking?
#239
No worries. I didn't have to do anything special this time to get the horn to be 90 degrees to the chassis. Usually I have to apply some sub-trim to get things perfected, but not in this case.
#240
If i upgrade the arms to the more durable plus one arms do i need to get the following parts as well?
YZ-4 +1 arms flat YOKZ4-008F1
L5 rear arms (YOKZ4-008RL5)
rear suspension mounts (YOKZ4-300LRF, YOKZ4-300LRR)
Do I need to get different drive axels too?
