Go Back  R/C Tech Forums > International Forums > Australian Racing
High Performance Nitro >
Old 06-10-2007 | 04:36 PM
  #1186
MassiveMods's Avatar
I cant see any pics ?
MassiveMods is offline
Old 06-14-2007 | 08:54 PM
  #1187
Mark, whats the story with your website?
RX7RX7 is offline
Old 06-15-2007 | 06:40 PM
  #1188
Why ? dont you like it ?
Old 06-15-2007 | 09:26 PM
  #1189
Hi All
I have had a few enquiries regarding engines leaning out after a jump, this will be beneficial to racers and bashers alike. What you find is when you gas it off a jump the idle rips up bringing the nose up, then you compensate with brake to tip it back .. sometimes this dosent always work out.. Especially those with sensative brakes. Most people will notice this happen suddenly after a few litres of run time and go everywhere looking for the leak ... Everywhere but the CARB BOOT ! ( dramatic orchestral stab ) OOOH ! pennies dropping ?
What happens is the carb boot is probably not made of a quality nitrol base and will soften and expand , this can happen on any engine as it is expensive to make one from nitrol .. about 11 cents more per unit !
SO ! what you need to do is seal the carb boot with a small thin cable tie where it reaches the carb stopping any air getting in ... You can put a dab of silicone around the base before the cable tie if you like , this should eliminate the problem , if it dosent then check it closely for tears and replace.
NOW ! why does it cause this problem ?
What happens is when you jump you are essentially clearing all excess fuel out of the engine , leaving not much in there, when you are in the air and the throttle is at neutral its closing the carb. The residual suction of an empty engine scavenges for fuel, if the boot is loose the air will be re directed through the side and by pass the inlet . that suction is wasted and creates a lean engine till you blip it again.
Now there are other problems that can cause these symptoms so make sure if you have it to check everything .
Hope this helps !
Cheers MassiveMods
Old 06-15-2007 | 11:46 PM
  #1190
so massive, you recon seal up the carb boot with a bit of glue maybe? i was thinking of doing this to my engine
TomB is offline
Old 06-16-2007 | 12:16 AM
  #1191
Nova JP's Avatar
Glue, ya enviromental bandit Tom. lol
I thought you Greens would be using tree bark chewed by 30 virginal Nymphs of the forest (security provided by a Yowi), after a little ceremony to thank the tree gods for aiding in the enhancement of your aura and lifting of your inner being, you know, to protect the overall karma of the whole ritual.
Nova JP is offline
Old 06-16-2007 | 01:50 AM
  #1192
DuDe ! im trying to type from the floor LMAO !!! Chewed bark ! lol A Yowie lol
Simon you have missed your calling lol
Old 06-16-2007 | 01:51 AM
  #1193
No , glue is as far as i know heat sensitive and it may crack from vibration .. the other thing Kev Lewis suggested is an O Ring .. which is a great idea !
Old 06-16-2007 | 02:47 AM
  #1194
Nova JP's Avatar
Neil's the name, Markov. I'm the good looking fella with anorexia from Newy. (didn't think I was that forgettable, go'n ta slash me wrists) lol
Has the O Ring you suggest bin vibration tested on the Massive Mods vibration tester (if you don't have one, get the one that Larry is using to satisfy the girl in the photo, lol)
Hey Tomo,
heard you prepared an environmentally friendly viagra for him, made by the druids out of hemeroids, goat gism and ginseng? lol
Nova JP is offline
Old 06-16-2007 | 06:39 AM
  #1195
Hey Tomo,
lol WTF??!!
ay Neil, Mark said he was after some "O ring" action, he said the O ring keeps it tight... WTF!!?? he said he will be going to Bali, or as the locals call it, "Barri"to hook up with one of Lazza's GF's friends
man dead set, i leave for 5 minutes and it becomes Jibber city here!
TomB is offline
Old 06-17-2007 | 09:54 PM
  #1196
Ah Neil ! thats right i always got you two guys confused, you look so similar lol
And Tom what do you mean beginning to be a gibber city , this is GIBBER CENTRAL !
Old 06-17-2007 | 10:52 PM
  #1197
CraigM's Avatar
you doing tempe on sunday massive?
CraigM is offline
Old 06-18-2007 | 12:38 AM
  #1198
Andrew Barr's Avatar
Also, when are you racing 1/8 offroad. There maybe an SMA attack on Liverpool on July 1.
Andrew Barr is offline
Old 06-18-2007 | 05:45 PM
  #1199
Noo im interstate ...
Old 06-18-2007 | 05:47 PM
  #1200
Noo will be interstate again ... sorry got too much going on out there , dont have time to play with my cars anymore :.. (
