High Performance Nitro
#1171
Well the MM stage 5 TZ is broken in and went really well at moorebank yesterday with the skyline pipe - sounds great too, really different to the nova pipes most other peeps run. It probably has too much up top because it's still trying to wind out by the time i hit the sweeper.
the only problem I'm having with it is the idle is a bit all over the place. It seems to get ultra lean and revs right up then if i give it a squirt it might settle back to a normal idle or it might do it again... any thoughts? The tune seems pretty good too, it's got heaps of squirt down low, goes hard up top and sits in the right temperature range
#1172
Ok irratic idle is usually caused by an air leak , try re bolting the carb in but this time push it hard into the crank case while tightening it.
Also check your pressure lines and pipe seals ... make sure there is no leaks , check tank seal too ..
Glad to hear it went well !
If you cant nut it out bring it round and ill have a gander
#1173
Hi All,
Sorry for hijacking your thread,
I would like to let everyone know about an great event that is coming up at end the June,
Please read the following below,
Gold Coast Cup Details:
!!!COME AND RACE ON THE NEWEST TRACK IN AUSTRALIA!!!
1/8th Saturday 23 June 2007
1/5th Sunday 24th June 2007
All funds raise from this event will be going into track infrastructure, i.e. new driver’s stand.
Format for 1/8th and 1/5th
One (1) Ten minute qualifier
Re-Grade
Three (3) 10 Minute Heats
Sort for Finals. Best Laps/Time (Result) of the three heats places you in the final)
C and lower Finals 10 minutes
B Final 20 Minutes
A Main Final Minimum 30 Minutes maximum 45 Minutes (dependant on entry numbers and available time, maximum 30 minute final for 1/5th)
Race Starts
1/8th IFMAR uncalled Qualifier and Heats
Finals by Lemans start
1/5th Rolling start Qualifier and Heats
Finals by Grid start
Scrutinering
1/8th and 1/5th cars will be held to current IFMAR rules.
Food and drink will be available at the track on both days ½ to ¾ Hr break for lunch.
Power & water on site, you will need extension lead and power board
Toilets a short walk away
What you need to bring;
Shelter tent
Tables and chairs
Extension cord and power board
For any one flying in for the weekend please contact us for help in supplying any of the above.
Practice
Track open for practice Friday 22nd from 12pm – 5pm
Practice Saturday and Sunday Morning 9am - 9.45am
Where is the Track
Frank Chaston Oval
Worongary Rd, Gilston (turn into the Frank Chaston Oval car park at the only traffic lights on Worongary Rd, opposite the Gilston Primary School)
Directions from the M1 available on club website
Entry Fee
$20 payable on arrival
Entries Please make all your entries on line at:
http://www.alycat.com/AlycatRC/Onli...ineEntries.html
Use pull down menu and select:
“GoldCoastCUPsaturday” for 1/8th event
“GoldCoastCUPsunday” for 1/5th event
Making entries online gives us a quicker entry time on the day and also gives us an idea of race day numbers prior to the event. On-line entries close 8pm the night before each event.
MAKING AN ENTRY ONLINE DOES NOT COMMIT YOU TO THE EVENT as a head count will be done on the day to confirm race numbers.
ENTRIES WILL ALSO BE AVAILBLE ON THE DAY but please enter early to assist in a smooth race day.
ENTRIES CLOSE 8.50am on each race day. Any on-line entry not confirmed by 8.30 on the race day will be deleted.
Track Specs and Photos
For racers who have not seen the track go to www.gcmr.org.au and check out the photos, if you have the current version of Quick Time there are some clips on the front page.
Other sites for photos are:
http://web.mac.com/optimal_logical/...e%20Photos.html
http://web.mac.com/optimal_logical/...ite/Photos.html
http://web.mac.com/optimal_logical/...n%20Photos.html
More info can be obtained from
Peter Gately
Founder/Secretary
Gold Coast Model Raceway Inc
www.gcmr.org.au
0413 128083
UP FOR GRABS
Trophies for the first three places
50mm Gold Medaleons for the remainder of A final
50mm Silver Medaleons for B final
We also have a fuel supplier prividing some fuel as prizes more details soon.
Re-Grade
B Final 20 Minutes
Race Starts
Scrutinering
Shelter tent
Tables and chairs
Practice
Where is the Track
Frank Chaston Oval
Entry Fee
Peter Gately
Founder/Secretary
www.gcmr.org.au
0413 128083
UP FOR GRABS
#1175
We got MM 3 in 1 avail !
heres the review on rubedude
http://www.rubeduderc.com/index.php?...d=324&Itemid=2
#1176
Massive you'll definatly be seeing our spare "barristic" 5L bottle
That stuff looks awesome
#1177
This is a Massive break through, especially for Off Road. So easy to use.
#1178
Nice! Will have to pick some up
Took the MM TZ up to the northern beaches and ran at Warriwood today, it's still very tight after 2 litres but it was really firing on their technical layout with great low down grunt and enough power to turn the r40 into a drift car. I was asked numerous times what engine I was running and also had the announcer comment on how zippy it was. I managed to settle the idle down by backing off the idle set screw, but i think an air leak is still present because the carby is completely closed now when it's idling. Next outing will be Tempe on the 10th
#1179
#1180
#1181
Is that with the venturi in?
Originally Posted by TomB
have a look at the piston sleeve etc condition and wear in process while you are at it
#1182
Originally Posted by Andrew Barr
I already have a bottle fresh of the production line.
I used it the other day at Livo with a really dirty filter .. it took off all the dirt and left a nice coat of oil on there ... popped the filter back on and kept racing
very convenient
