SMA Night Racing
#1396
When you talk pinion and spur i usually talk in terms of rollout, most of the XRay guys work by whats called the Final Drive Ratio.
You can calculate both of these at gearchart.com
Basically you slect your car from the list and plug in the details and it gives you a little chart.
When working the rollout enter 63mm for the tire diameter.
Ideally you probably want to work with a rollout of around 40-44mm at SMA.
With a TC 4 i think you can use a small spur a 66 but dont quote me on that. Then when you have the chart from gearchart.com you match up and find what pinion you need. Getting a pinion for a rollout of about 42mm would probably be a good starting point then after running with that you can compare your speed relative to the other cars and the equipment in them, ie some cars may be a little quicker anyway if they have all the you beaut stuff.
#1401
#1402
Cheers
Rob
#1404
poor robby
I can bring an angle grinder to work thurs night .GGGGRRRRIIIIINNNNDDDD,oops wrong place
#1406
hiroshi
Hey didnt anyone tell you hollywood movies arent real ,they use stunt men .Or are you trying for a insurence payout .Waits to see if hiroshi has new car next race meet ,hope your ok
