Supernova Competition charger?
#91
Originally Posted by pullstarter
Has anyone tried the SJ Platinum EX of the Supernova 3000? Are they comparable to the comp or just updated versions? Is there any advantage to the platinum over the 3000?
cheers
Simon
cheers
Simon
yeah mean there is a newer version out now??
#92
These two are at RCHobbies, i dont know if theyre new versions or what, just wondered if anyone knew anything about them, if they have the same features as the comp?
http://www.rchobbies.com.au/store/pr...f229716afc2c53
#93
#99
my supernova went up in smoke. i sent back to Radiomodels and they sent back to modelengines, and 2 weeks later RMS call me and tell me they are sending me another one, some faulty part in it..... THanks radiomodels for your great service
#100
-hacker ESC BLOWN UP!
-kopropo mars R reciever BLOWNUP!
-EAGLE cdc charger BLOWN UP!
-much more PSU BLOW UP!
#102
Originally Posted by ford_racing
off topic but how did you manage to blow up a reciever?
i don't know but i put a capacitor in the spare channel, and the car drove fine, then just shut off. i also shorted a pack on my chassis this day not sure if this is what blew the reciever or what.
since then the reciever would only work from 2 or so metres away, any further it would glitch
#103
When you turn off button sound, does that also turn off the "finish charging" sound. Because, i turned off the button sound (its annoying when you're setting up everything) and then i proceeded to charge my 1st pack. Well, the charger was flashing *END DELTA PEAK* but theres was no sound...I terminated the charge anyway because the pack was in teh right temperature range, but im not sure if charger didnt chime because i had turned off button soudn, or because i had not let the battery reach teh cutoff temperature...
#104
I've been using my Supernova Competition Charger for almost 6 months now and haven't had any problems.
#105
question about the SN Comp charger
g'day all, got a couple of questions re my Competition charger.
Is there a way of scrolling the graph view across when charge or discharge time is longer than can be displayed ?, I have used the zoom but does not display all the graph.
AND
On the graph display what is the little cross in the bottom right corner above the magnification setting ?
Many Thanks
AND
Many Thanks
