Wa Onroad Racing
#166
Rubbers
Do the club's still have the right to choose what tyre to use at club meetings
#167
Looks like this rubber tyre thing is causing a lot of problems... then again, how would I know? I don't even race!
#168
It's only a problem if you make it one, at least everyone is in the same boat, and will be using the same tires and will have the same amount of sets, and not being limited by their budget. After all, tires are the major part of setup.
How can rubber be too complex. A tire is decided on before the event, you get your sets, you set your car up, and your done. None of this put your foams on, set your car up, run a race, the re check tire diameter, re set ride height, re set droop, re calculate roll out, pretty much every run.
Rubbers means more time to socailise between heats
#169
But everybodies laptime will drop, not just the guy that can't afford new tyres. Correct mee if i'm wrong but the number of sets to be use dis limited as well, so everyone is the same. Just need to look after your tyres, just like real racing, they are supposed to scale touring cars after all, you don;t see Mark Skaife driving on foams.
Originally Posted by Besercoe
And repeat the process every 3-5 runs. Everyone should try 5-10 run tires keeping lap times, bolt a new set on and see the lap times drop.
#170
tyre
Having a controlled tyre and limited quantities is where the sport of r/c car racing is headed.just have to get it back on off road
#171
Rubber Tyres
So the club decides what rubber tyres to use or is that only on states and nats?
#173
The club decides what tyres you can use on club meetings anyway, it is the club rules. Only on AARCMCC sanctioned events, such as AARCMCC state or National titles is a rubber control tyre selected 4 months prior to the event.
#174
tyre warmers, thats what i got to get too
#175
so for sunday racing at ryper is it controlled too?
#176
Unless we can get a club to propose tyre warmers be banned on the grounds of cost control, as they are in the UK for all santioned events.
Originally Posted by b3n
I prefer foams. After running for a few years on rubbers and then changing to foams at the start of the year, I now know I should have changed I long time ago.
Plus, with rubbers there is another thing to spend my money on.... Tire warmers
#177
Not as far as I know, I think Dave likes foams too much
#179
have got too many sets of foams so i hope it stays the same
#180
Periwinkle check your PM.
