Sydney Model Autosports Inc [smaracing.org]
#9586
Thats not surprising from one of australia's fastest drivers. I'm sure both he and jake could get down to 14.5 or better if they gave it their best. But the guys in 10.5 went slower... even than they did on tue night which seems odd. I have been told the track is faster on sundays.
Anyway make sure you pack some speed when you come down ACT next weekend.
#9587
#9588
You better keep this in mind if SMA wants to hold sanctioned events. I think there is a 15 second minimum lap rule or is this for nitro's only? Just double check to see if there is a min lap time rule, you might need to add a few bits to slow the cars down just that fraction
#9589
#9590
#9593
FXII gives steering at the expense of stability. Only good when your car is planted which is comon with sorex. It can also be used to enhance another goop by using for a short time then cleaning and adding a layer of something else. As far as goop goes its hard to go past Trinity tire tweak or Muchmore Z1. Both have the same effect with some minor differences. There is more in how you use it though than what you use so you need to figure out what works best for you.
#9594
track
Not sure but I think this was demarcos track
#9597
We could always run the track though the club, past the pokies, into the TAB area and across the bowling green .
Tom, when are you coming racing??????
#9598
