HOBBYWING TECH SUPPORT INFO
#361
Can anyone from Hobbywing tell me when the new Xerun XR10 Pro will be available for purchase in the U.S.? I sent an email to Hobbywing North America a couple weeks ago and never received a reply, and when I call nobody answers. I seen on the main website where it says it will be avialable end of the first week of April. I figured if that was accurate you would be available to pre-order them by now.
Any tech issues please do not hesitate to contact me [email protected]
#362
#363
Ezrun 35amp combo 13t
Is it true this combo has stopped being produced ?
Also in the motor the bearings need replacing , does hobbywing do a ceramic "upgrade" ?
#364
Im 100% sure there are a few 100 combos still floating around.
No ceramic bearing upgrade from hobbywing but im sure you can get ceramic bearings to fit.
#365
I've owned 2 hw v2.1 and on 6 degree dead band the esc causes the car to stop suddenly when on brakes and then on throttle. This happens on any firmware. 9 degree dead band no issues. Is this a known issue with the v2.1
#367
If you calibrate radio to esc once again it will go back to normal.
#368
Tried that. No change. This happened not long after with a new esc, not used
#369
Make sure you calibrate the esc with the dead band at 6 degrees. Don't calibrate at 9 degrees and the change the dead band setting.
#370
The 35A/13T combo is the spec system for mini class in Australia. It sounds like this will need to change soon as a result. What system would you recommend as a replacement? Ideally one that has equivalent performance, has a similar cost, and won't be discontinued any time soon.
#372
Hi kobiwan,yes there is a punch adjustment on the new XR10Pro,with the new speedy both the punch and brake are now just one setting each,not split into two,its call throttle rate control now.
cya
cya
#373
Hobbywing Xerun V3.1 120amp
I have a couple of Xerun 120a V3.1.
I have found this on the internet.
http://www.ebay.com.au/itm/Hobbywing...4AAOSwgApXBdog
The beginning of the Spec notes state
XERUN - V3.1 - Competition ESC 120A
Due to the way this ESC is manufactured, the sensor lead cannot be removed from the ESC and is approx 100mm long. For long reach applications a sensor lead extender must be used.
Repair is not available on this unit as it is completely sealed inside.
Are Hobbywing manufacturing these ESCs with a permanently wired Sensor lead. As I have found the sensor lead often fails and needs replacing.
I have a used ESC, I bought with a car with a fixed sensor lead that I cannot use as the sensor lead has failed.
Is this a genuine Hobbywing Xerun V3.1 120a. Ill have to be careful when ordering a new HW esc not to get this model if it is.
Cheers
Cheers
#374
I've got a 3.1 and it looks different to that one. For starters, my one has a detachable sensor wire. It also has the fan plug in the case, not as an external lead. The power button is on the case too, not on a separate lead. If you look at both pictures on the eBay listing you will see what I'm talking about - my one looks like the picture on the box.
#375
The one in the photo on the box.
Like this....
So is this other type made by Hobbywing?
Thought the representative would know the answer!
