The Xpress Mini Thread
#17
As this review suggests, the new layout is a lot better balanced with the new servo location.
http://www.rc-xpress.com/download/MR...K_RRCi0308.pdf
With the double bell crank steering design, with such a small light weight car it works very well.
I might get a tensioner in the future but so far there has been no problems with the belts.
When its all said and done, i believe that if you were to race it, the best bet would be to go for the pro and save the money in the long run from upgrading the junior with the carbon chassis etc.
If you were to just run it around the tennis/netball courts for a bit of fun, the junior would be more than capable to have great fun driving!
#18
i've heard some guys have had to drive this chassis in their own class or touring because it's too fast. is this the case? sounds like a gun!
#19
Too fast to be raced with Tamiya M03 Mini's yes - it has normal touring car style gearing, so you can outpace M03's very easily.
Can't race it with touring cars, as it would be extremely difficult to get it up to the weight limit!
#21
Sweet car you can also get a 1200 ute as well .
#22
I have an older Mini PRO with a broken lower deck. How much of the parts can I transfer to the new MRR2 PRO model? e.g. front/rear bulkhead, uprights etc... Thanks.
#23
Hi everyone, i m interested in this mini car. Just want to know if this car handle just as the normal 1/10 touring car? I ll be using nitro foam tyres on asphalt/tarmac track. Will there any rubbing issue with the body or with the suspension arm it self? Nitro foam tyres width 26mm for front and 30mm for rear.
#24
Tire rubbing 'might' be an issue on the ball links - i had Team Power 36's on my car (mini tires) and some of the balls were scrubbed up a bit due to the rim.
I never had issues with tires rub/suspension rub on mine - it had a Datsun 1200 Coupe shell on it.
You'll have to get one of the guys that has the car to measure the clearance for the nitro tires - i sold mine after very little use. I'm planning on replacing it with an Active 210 in the near future. That's probably a good indicator of my thoughts on the car
Good car - cheap (the Jnr is at least). Pretty much bult straght outta the box (you really only have to blt on the wheels and install radio gear!) But i found it to be fragile and I always seemed to be replacing parts after even soft hits that my M03 wouldn't even concern itself with. That being said - parts were cheap, but I don't think that justifies a 'soft' car that can't handle a tap here and there.
#25
My car handles very well with the foams and 1200 body.
Just need to fine tune the setup a bit to get it 100% right!
#27
Hi Itch b, i pm you before i post my q's here, anyhow yours is the mrr2 pro v2.1 right? Do you have any durability issue with it? I m going to put a 5.5 brushless in it and i ll be running/racing it against the normal 1/10 touring (my local club actually allow this) on an outdoor asphalt parking lot track. Any advice which parts should i stock?
