Any Topic Thread.
Old 07-02-2002 | 03:38 PM
  #301
Company Representative
It sounds to me like you have the incorrect servo horn on. Make sure that it is for a Hitec servo, we have a 24 tooth spline. THe 25 tooth(Futaba) will fit on but it will shift around causing the problem you have described. TTYL.
Gary
Gary Fliegel is offline
Old 07-02-2002 | 06:27 PM
  #302
KopiO's Avatar
Gary,
I'm using KO servo horn which came with the kit. it happan when the FW on the ground, it needs to re trim to get Fw point forward.
Thank
Roy
KopiO is offline
Old 07-02-2002 | 06:55 PM
  #303
Tres's Avatar
The KO horn is a 23 tooth horn
Tres is offline
Old 07-03-2002 | 12:36 AM
  #304
KopiO's Avatar
Default 625MG
hmm, most of car kit supplies KO/Swan or Futaba servo horn.
KopiO is offline
Old 07-14-2002 | 01:51 AM
  #305
fabolousRC's Avatar
When are you guys going to redesign some the transmitter..I thought when the lynx sport came out every single other pistol grip transmitter that Hitec sells (except for the 3D) will going to get refreshened. Is there anything that in the plans of doing this?
fabolousRC is offline
Old 07-14-2002 | 06:56 AM
  #306
As with any company, ya never now, Heh.
Gary
Old 07-22-2002 | 05:57 AM
  #307
Default Retail shop in Asia?
Hi Gary,
I'm staying in Malaysia and I was wondering if you can point me to a retail shop around asia that stocks Hitec radios? I had a look at www.rotor.com.sg (in Singapore) but when I contacted them, they do not stock any Flash 5 SX's. It costs too much to ship a radio from US. Thanks for your help.
SkyVoyager is offline
Old 07-24-2002 | 12:45 PM
  #308
Turbo9000's Avatar
Hi, I have a HS-945mg and a HS-925mg in my mbx4, My receiver pack(600mah) is good for about 1-2 hrs. I cannot get the throttle servo (925) to stop twiching, does that account for the short run-time,or do these servos naturally drain batteries fast due to the hi-torque and hi-speed capabilities. ( I was able to use the same pack 4hrs with standard servos)
-thanks for your help
Turbo9000 is offline
Old 07-24-2002 | 02:40 PM
  #309
Those servos will draw more current than a standard servo, especially in an 1/8th. My 1100 mah Rx pack will go for about 1.5 hours in my 1/8th buggy, using the digital servos. So yes the servo will start to twitch after a bit when the voltage goes down.
Gary
Old 08-11-2002 | 01:53 PM
  #310
I have an extra servo that had been strip of its gear, so I went out and got a new hs 625mg but no I got a good one just with broken gears where do I get replacement gears for it?
its a hs 303 servo.
thanks
HiepNOtik is offline
Old 08-12-2002 | 06:30 AM
  #311
Tres's Avatar
HiepNOtik: You will need part # 56325
They are the same as the ones for the HS-300.
Your LHS should have them or get them for you.
Tres is offline
Old 08-21-2002 | 08:28 PM
  #312
help! Thinking of going dig with servo. Will the 5925mg fit a b3?
thanks for any advice.
mwaeracer is offline
Old 08-22-2002 | 05:02 AM
  #313
Tres's Avatar
mwaeracer: yes.....
Torque 4.8/6.0v : 103 / 128 oz. 7.4 / 9.2 kg.
Speed 4.8/6.0v : 0.10 / 0.8 second
Size : 1.2"x 0.8"x1.5" 39 x 20 x 38 mm
Weight : 2.0 oz. 56 g.
Tres is offline
Old 09-02-2002 | 09:10 PM
  #314
newracer's Avatar
I have several rx crystals that the tags have come off or are in really bad shape, can I get replacements?
newracer is offline
Old 09-03-2002 | 06:03 AM
  #315
Tres's Avatar
newracer: ????
I made some with one of the cheap label makers....
Worked good...
Drop an email to:Mike
Tres is offline
