Any Topic Thread.
#197
Hi!!!
good evening form Spain, somebody can tell me what happened with the Factory drivers program??, i saw it in the past, but at that years i think that i was just not good enought to send a serious aplly for it, any info is welcome
thank you very much in advance!!
Alvaro Villar
Tamiya-LRP
Alvaro Villar
Tamiya-LRP
#198
#200
Tres: Because the glitching only occured when I applied throttle, my first thought was that it was the motor. I cleaned the comm, and even switched the brushes. I eventually switched motors all together, with the same result, glitching when I applied throttle. I then swapped the positions of the receiver and speedo and added one more layer of tape under the receiver. That pretty much did it.
Theres really no need to swap them back since the layout actually gives me better access to the pots to the XXtra.
I like the combo so far. Unfortunately, I haven't been able to test it in racing conditions yet. Its still a little too cold here.
#203
Can't find specs on the HFX-R on www.hitecrcd.com - can some of you guys please tell me what the specs are?
#204
Company Representative
Here ya go,
6-7 cell operation, 162 A forward Current, 100 A Braking current, 1900 Hz operating Freq, 10 turn motor limit forward, 12 turn limit reverse, One touch set-up, BEC is 5v at 1 A. IR is 0.004 ohm forward, and 0.008 ohm reverse.
TTYL, Gary F.
TTYL, Gary F.
#205
Gary- How is the 225MG for 1/12 on-road use? I am assuming it will get the job done but was curious about centering etc.... I have exclusively ran Hitec since I began racing last year and have had NO problem (except for a 605bb
) and I am very pleased. Just was hoping I could expect the same with this servo for my new application!! Thanks!
#206
wilson10: the HS-225MG would work great in a 12th scale...
I use one in my SPEC NASTRUCK...
Specifications:
Bearing Type
Top Ball Bearing
Operating Voltage: 6.0v
Torque
oz\in 67
kg\cm 4.8
Speed @ 60 degrees: 0.11
Size L x W x H 1.3 x 0.7 x 1.3 in.
Weight 0.98 oz
1.13oz (MG)
27g
32g (MG)
Specifications:
Bearing Type
Top Ball Bearing
Torque
oz\in 67
kg\cm 4.8
Weight 0.98 oz
1.13oz (MG)
27g
32g (MG)
#208
Originally posted by Gary Fliegel
Here ya go,
TTYL, Gary F.
Here ya go,
TTYL, Gary F.
#210
Man, I guess I sound kinda crazy about the foam trigger things, or I'm the only person who actually likes the things or something.
I certainly figured after contacting Hitec and attempting to buy the darned things, that I would get some kind of help or something happening for me.......
Mike asked for my address, I offered to buy them from the company if I could get a part number or something, still nothing.....
....crap, I guess I'll have to make my own.
So my new 1/12 and all will be here next week
