using channel for flaps
I have a HiTec Eclipse 7. I want to use channel 7 for flaps. I would like to
start with the switch in the rearward position and the flaps be up. When the
switch is moved to the forward position, the flaps should go down.
I have both flaps operating on one servo.
Is this possible?
ron shenk
Is this possible?
ron shenk
Are you trying to set this up in the ACRO mode?
If you are then channel 7 is controlled by the VR2 knob. You can use PMIX 1 or 2 to mix channel 7 to itself and then the channel 7 switch will control this channel along with the VR2 knob.
