Team Magic G4
Old 06-27-2007, 05:16 PM
  #7396
Kodak Hodak's Avatar
Originally Posted by Z00M
At least you can call them in Aus and at a sensible time too - And yes they have all the parts on the shelf as the owner races a G4S himself. As for RC Mart - Good luck there, have you seen their thread?
Anyhow, back to the goodness of the G4S and G4+.
no dramas with RCMART - delivered my goods always, i guess some get unlucky bit like that everywhere!
Kodak Hodak is offline
Old 06-27-2007, 05:25 PM
  #7397
uniquexme's Avatar
Trader Rating: 12 (100%+)
gansei, where did u get that CF brake lever? or do u just paste a piece of CF ontop?
uniquexme is offline
Old 06-27-2007, 06:54 PM
  #7398
gansei's Avatar
yes, it is 0.5mm real carbon sticker
gansei is offline
Old 06-28-2007, 02:34 AM
  #7399
gansei's Avatar
Default G4+
G4+ rear hinge pin shaft was chagned "60.5mm"
i cut off G4S stock shaft 3-4mm
gansei is offline
Old 06-28-2007, 07:55 AM
  #7400
muppet racing's Avatar
Hi gansei,
No not that part, I mean part 502193, at the bulkhead end.....
Good Luck.
muppet racing is offline
Old 06-28-2007, 08:30 AM
  #7401
gansei's Avatar
Originally Posted by muppet racing
Hi gansei,
Good Luck.
oh i see, thanks..
i will try like this!!
gansei is offline
Old 06-28-2007, 10:41 AM
  #7402
gansei's Avatar
Default G4+ parts TEST
i tested G4+ new parts on today.
i did not run my G4S.. only starting engine and Throttle test etc on..
1. new black clutch shoe.
i hold rear tire with full throttle.
i feel more meet(grip) feeling than old back shoe.
and i look up the black shoe.. i could find no wear out than old back shoe.
very satisfactory parts!!
2. new 2nd shoe and housing.
new 2nd housing was smaller than old one.
so i quess 2nd timing was faster than old one.
i locked the 2nd shoe bolt until bolt bottom did not project in opposite side.
as expected.. 2nd timing was too fast...
so i put 1.2mm (3X5)shim under bolt head.
then.. i can setup 2nd timing properly..
if bolt length was shorten.. it can be fixed too.
can i call my G4S as G4+ fairly? ha ha ha ha ha
gansei is offline
Old 06-28-2007, 11:55 PM
  #7403
uniquexme's Avatar
http://rc-mushroom.com/product_info....ducts_id=13482
i have found the G4+ shock. but rather expensive, they sell in set of 2pcs. damn. gansei, go get and let us know if its better than the stock
Old 06-29-2007, 12:04 AM
  #7404
gansei's Avatar
i see the new G4+ Shock.
G4+ shock head cap had small hole like mugen shock cap to discharge shock oil.
shock rubber also changed.. looks like Kyosho offroad bugy shock rubber.
and shock end ball was changed to particular shape
But i had no plan to test new shocks..
because i am using Knack Shock... if i willing to test it, i must buy it.
i had no money to test all G4+ new parts!!!!
gansei is offline
Old 06-29-2007, 02:34 AM
  #7405
Pattojnr's Avatar
Trader Rating: 19 (100%+)
might be time to start selling your shares in the carbon fibre industry ?
Pattojnr is offline
Old 06-29-2007, 03:59 AM
  #7406
British Menace's Avatar
British Menace is offline
Old 06-29-2007, 10:11 AM
  #7407
gansei's Avatar
Default UFO -> UFO2 changed parts
http://rc-mushroom.com/product_info....ducts_id=13474
gansei is offline
Old 06-29-2007, 05:24 PM
  #7408
uniquexme's Avatar
yo gansei, haha, no worries, i will see if i can get hold of this G4+ shock. keke.
Old 06-30-2007, 07:38 AM
  #7409
gansei's Avatar
Default UFO2 Shoe Problem
i tested my G4S (80%-90% G4+) in today
i found UFO Clutch Black Shoe Problem.
shoe was pressed down by bell and shoe changed sharp shape.
when i tried first about 10 fuel tank run..
there are no problem in shoe.
But after 10 fuel than.. Clearance(clutch gap) changed each 1 tank run.
i checked shoe.. and i found the new black shoe(UFO2) had bigger diameter than old Black shoe.
clutch bell had same diameter of UFO2 NEW shoe.
i think clutch bell's diameter must be larger than Shoe's diameter.
if not and had same diameter.. clutch bell edge will press shoe edge..
then shoe will be wear out in sharp shape.. like my shoe.
how about you think?
i consider cutting UFO2 shoe to have small diameter.
Attached Thumbnails Team Magic G4-sany0001.jpg   Team Magic G4-sany0002.jpg   Team Magic G4-sany0003.jpg   Team Magic G4-sany0004.jpg   Team Magic G4-sany0005.jpg
gansei is offline
Old 06-30-2007, 07:39 AM
  #7410
gansei's Avatar
Default UFO2 Shoe Problem2
is released UFO2 NEW clutch Bell have big diameter?
Attached Thumbnails Team Magic G4-sany0006.jpg   Team Magic G4-sany0007.jpg   Team Magic G4-sany0008.jpg
gansei is offline
